Adventureboy
Unfortunately, this only works if you drive daily. It doesn't work if you don't.The LVB is charged from 35% to 90% in about 20min, so charging speed shouldn't be much of an issue unless its in the dead of winter and you're taking the whole family 5 miles fown tge road with heated seats, cabin heater and defroster running, at that point you might end up with less SoC than you started with, but during normal circumstances this should not be a common occurrence.
If people are still concerned due to short commutes, don't shut the truck off, let it run and shut itself off after 30min.
