Andrewbens
Modesto
Lightning
Mechanic
Dope mod!
MachLightning
Eric
2023 Mach E GT, 2022 F-150 Lightning Platinum
I love it! I'd love to do something like this. I really wish Ford would have included animated lights. Even if they were simple like the Mach E. I've had my eye on the Putco animated light-up Ford emblem for the front grille, but they want waaaay too much for it.
MaintGrl
Marsha
El Sobrante, Ca
Slick, I like it...
Ted23Lightning
Ted
Mobile ADAS Technician
I used an ESP32 to add a little animation sequence to my raptor lights.
Love it! Any issues with the front SVC?
Ted23Lightning
Ted
Surround view camera. The 360 degree view that shows up in the infotainment center. The camera for it is part of the front Ford emblem, at the bottom of it.
Telemachus
Lightning
I can see a tiny bit of the R in the upper left. But other than that, it lines up perfectly.
Ford F-150 Lightning Animated Raptor "FORD" Letter Grille Lights 20250524_180033
LSUT1GER
Slidell, LA
Computer Engineer
Can you send more information? Where you got the parts and how much? Did you do it all yourself?
Telemachus
Lightning
Ted23Lightning
Ted
Grille: ( I got off eBay, but same thing)
https://a.aliexpress.com/_msjswPR
You see my photo above of the letters that come with it.
Letter Lights:
https://a.aliexpress.com/_msHF8qN
Code and circuit for animation:
https://wokwi.com/projects/435976606565505025
12v to 3.3V stepdown:
https://a.co/d/iME5ZBV
ESP32C3
https://a.co/d/g00qXeU
Solid State relay board
https://a.co/d/cg9nMiE
Then a waterproof enclosure and a some wiring... And a good amount of fiddling.
Sweet! Thank u for the parts list. Might have to give this a try if I don’t go the illuminated Ford emblem route.
Telemachus
Lightning
Putco Emblem is a much easier route, for sure.
In my case my OEM grill got smashed up, so this was cheaper than buying a new one.
mklcolvin
Louisiana
2022 Lightning Lariat LR, 2023 Hyundai Ioniq 6 SEL LR, 2011 Honda Insight
Retired; Former Systems Engineer
