Rear Lightning lettering glue issues
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
Seems a 6-hour drive in direct sunlight is enough for the glue to fail. I pulled these off before loosing them to highway wind. Anyone know what kind of glue is needed to stick them back on? Looks like the entire decal needs resticking but the other letters seemed to be stuck on enough, hopefully…
Ford F-150 Lightning Rear Lightning lettering glue issues imag
Altivec
o_O I never heard that from happening before. My truck that's antimatter blue gets super hot in the sun. I have it sit all day long in the sun and that doesn't happen.
there are 3m double sided automotive tape you can get but they usually have a slim foam centre. Not sure if they will end up being different heights from the other ones. If it were me I would definitely take it back to Ford under warranty. Must have been a defect when applying adhesive to your letters.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Antimatter blue too. Out of warranty now so will need to take care of it myself. Maybe I’ll reach out to ford and see if they can send me a new one as a goodwill gesture - I can’t see these costing them more than a few cent.
3rd rock
Automotive Technician
$35 looks like. Can't tell if that's one or a pair as it says fits left and right.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Wow, but not really surprising… I’ll figure out some glue and just glue it back on. Not sure if the letters that I removed had sticky pads or just some kind of glue. May just have to take it all off and clean it up with Gue-be-gone.
It's not glue, it's double sided tape. 3M makes different widths and thicknesses. You just need to find the right size.
I replaced the tape on some trim on my golf cart last year. It was pretty easy but I only needed to attach an "I" so there was minimal trimming.
Adventureboy
Ontario
This is what I would do. You may have had a batch of bad glue on yours and the other letters may still have issues. It comes packaged with the adhesive already on the letters and proper transfer tape on the top to keep accurate spacing.
Clean surface (remove any wax etc.), peel and stick.
Edit: It is for one set only. You need to order 2 if you want both sides.
Ford F-150 Lightning Rear Lightning lettering glue issues 1764601069753-io
MaintGrl
Marsha
El Sobrante, Ca
Yes, with those raised letters, I have been worried that some SOB comes by and flicks a few letters off just to be a . A-____
But after nearly 2 years no problems so far...
nate002
nate
‘24 Flash | Antimatter Blue | 9.6kW Pro Power
Thank you for the link, I’ve been looking for these.
3rd rock
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Thanks @Adventureboy - I'll keep this in my back pocket. I'd rather avoid having to pay for them since I still have all the letter parts (unless I lost any on the way home). I'll see if I can get hold of some adhesive tape and fix it first. Failing that, I guess $35 is a cheap fix.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Finally got the glue removed from the lettering and the truck panel today. Used the lettering spacing on the other side of the truck to make sure my spacing was good and when I went to apply it, I noticed that the residual marks where the previous lettering was, was incorrect! The T in Lightning was adjusted so the bottom of the T was level with the bottom of the lettering and the other letters in the word were pulled in closer to the T. Very strange. Don't have a good picture of this unfortunately but you can see here that the top of the T is above the other letters. Wondering if this has been fixed previously in the past. Hopefully the 3M adhesive strips will hold...
Ford F-150 Lightning Rear Lightning lettering glue issues 1766367635491-zc
Ford F-150 Lightning Rear Lightning lettering glue issues 1766367775355-va
Also touched up my mud flaps too :)
Ford F-150 Lightning Rear Lightning lettering glue issues 1766367830421-pf
Adventureboy
Ontario
I have a suspicion that your original panel may have been repainted, perhaps due to a transit incident, and the shop didn't use a new decal.
