Steering Wheel Torque Driver Monitoring Defeat Device - Testers Full
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Comma...
If you're driving in a coma, we have big problems.
LOL,,,, Rick, if you already have comma, yea no need.
I'm curious, for all Lightning owners, do you only let Comma do Lateral control? I've heard that's the way it is. I've considered getting Comma to become familiar with it so I can help with the torque interceptor project.
BluesClues
2022 f150 lightning sr lariat
Yeah, most current recommendation from users here is that Ford ACC is superior to OpenPilot (OP) longitudinal (long) control.
Comma.ai claims that OP Long is superior to Ford ACC. But just like the models, YMMV based on your area, conditions, etc.
It's possible Chestnut (eGPU) class models overcome this & then are distilled to better small models.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Since you seem to know a lot about Comma, I suspect the Comma doesn't have access to the forward looking RF radar b/c it's on a private CAN bus?
If true that totally explains why it wouldn't be as good at long control?
Does Comma use radar info from any of the OEMs?
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
I’m happy to sell my defeat device for you all….
There's a great old tech story (who knows how true!) of someone setting up a remotely-accessible computer's CD tray just right so they could login, open the CD tray, and have that CD tray press a physical button remotely.
If it's stupid and it works, it's not stupid :D
Edit: Found it! https://thedailywtf.com/articles/ITAPPMONROBOT
evowner
Frank
SW Ohio
2024 Ford F150 Lightning Lariot
Retired EE
Where are the installation instructions? Do you have to cut a harness on you vehicle. Does this only operate when you are in the specific mode.
Paulb55
Paul
2024 Lightning Lariat
Im in, would love this
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Great idea, I will test something similar soon.
galightelec25
Joshua
Forsyth, Georgia
25 Ford Lightning Lariat, 20 Ford Expedition Limited,
Since it's not likely something I (myself) will want to sell for liability reasons and I'm not in it for the $$$ I'm not concerned with any IP. I'm using his board for the prototype:
https://copperhilltech.com/teensy-4-0-can-fd-and-lin-bus-breakout-board/
If you want to buy one, I'll send you the few other parts, program, and details on how to plug it into the truck,, it's super easy, takes about 5min.
If anyone else here is curious why not just stop here and give it to the community like this, it's because this device should cost less than $50,, maybe it's not worth it, maybe we just need to stick with the DIY approach since we all know someone would buy this and decide to take a nap on the highway :(
So do we need to do Dm you or anything?
amoren
Adam
Minnesota
2023 lariat
Would someone running a Bluetooth or USB OBD connector run a phone app to do the same as your method or are the buses isolated from each other?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
In this exact moment, I hesitate to say how easy it is to install because I already have 10+ people asking me to test it, but, I have a VERY simple method of stabbing two probes/wires into the CAN-FD bus wires on the connector that Comma uses to middle man the same bus. This solution is very passive, it only injects button presses at microsecond accurate/coordinated times. Here is a picture of the installation, it can be installed in just a few minutes.
Ford F-150 Lightning Steering Wheel Torque Driver Monitoring Defeat Device - Testers Full 1787249993236-mt
Yes, it also monitors the ADAS system status and only injects button presses when the system IMPA is in active land centering mode and happy.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Not sure exactly what you are asking here, but NO, this can not be done from the OBD port. If that was possible there would immediately be devices available form china the same month the truck was released :)
The Weatherman
South Central KY
DMed you Zack.
I <3 My Lightning
@ZSC100 Not to derail and not sure if this can be applied and worked out with your abilities... Where is the pro-power version of pushing the little green outlet button on an unused outlet to mess with pro power with the truck off that is trying to turn off at 6 minutes with less than the minimum load? :idea:
