“STOP SAFELY NOW” message
256fail
Alabama
23 F150 311A XLT
Pilot
This morning I got in the truck to take my kids to school and after unplugging and starting the truck I had the red " Stop Safely" message pop up. I had no other warnings or issues. The truck appeared to be on. I turned it off and turned it back on with the same message appearing. Ford Pass shows no alerts or warnings which is odd.
Not having time to figure it out, we quickly got in my wife's car to get the kids to school. I came back :40 later and started the truck up and the warning is gone. No issues. I decided to test drive the truck and it behaves completely normal.
Is this a glitch?
After owning two ICE 22 F150s this year with no issues, I'm starting to get a little rattled with the truck. 2 weeks ago I inexplicably had the reduced power 64% with the front motor drive not working on a normal day. It went away again with a restart of the truck.
I'm curious if a lot of this is caused by faulty 12V batteries?
Adrian818
Adrian
2022 f150 lightning
I just had the same problem, except I also lost power. I turned the truck on and off a few times a few times and it started working. Anyone else have the same issue?
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
What were the available power reading (left side energy meter) ?
If it was less than 100% available, please post how much the truck is reporting ?
Hatchback
Pete
Silverado 1500
I also had this happen yesterday. It occurred on the first start after pulling fuse 32 to reset the modem. It went away after shutting off for a few minutes. No reduced power while message was displayed.
256fail
Alabama
23 F150 311A XLT
Pilot
This was my exact scenario. I still have the modem disconnect issue and refuse to pull the fuse again, for fear of causing this message or more issues.
By chance were you charging at the time when you reset the fuse?
Hatchback
Pete
Silverado 1500
Correction…it was plugged in waiting to charge. I pulled the fuse one prior time when not charging and no codes.
256fail
Alabama
23 F150 311A XLT
Pilot
I had the same scenario. I was plugged in, but it wasn't set to charge until the evening. I have a feeling that had to do with the code.
BennyTheBeaver
2023 Lightning XLT ER
Just had this issue while driving. I was using 1PD going about 35mph, for a split second I lost acceleration and all my gauges reset, then "Stop Safely Now". I had 2 warning lights in the bottom of my HUD (Yellow Wrench, and a Red symbol of the truck with an exclamation point). Luckily I was within 2 minutes of my dealership and took it straight there without turning off the truck, they're currently looking at it.
kgilcris24
Kayne
New Hampshire
2023 Lightning Lariat ER
Automotive Parts Sales
Can also confirm this, had the please stop safely message this morning after pulling fuse 32 last night while plugged in. No other warnings, no reduced power, truck drives normally. I had previously pulled the fuse while not plugged in with no issues.
Sorry if I missed the update somewhere else, was the dealer able to figure out what happened?
BennyTheBeaver
Unfortunately no. The dealer blamed it on an OBD device I have in my truck (lowers my Registration fees in my state). That 99% isn't the case though or there are bugger issues.
I think they may pull one of my modules and send it back to the mothership for analysis.
Ya the only thing I could see the OBD device complicate is unintended LVB drain. But since the truck was on, that shouldn't be a problem. Really wish people wouldn't be so afraid to just say "I don't know" instead of feeding us clear BS.
JonS
Jon
Tesla Model S Plaid, Tesla Model X, F150 Lightning
I've had this error message appear twice. Once when I was futzing around with the fuse to reset the modem. This was resolved by pulling the neutral on the battery and resetting the system.
The 2nd time was when my Tesla Wall Charger and TeslaTap Mini put the truck in a funny charging state and nothing would clear it. I eventually plugged in my Ford Mobile Charger and it reset things and the truck started working again.
https://www.f150lightningforum.com/...l-charger-teslatap-mini-80.14858/#post-306810
FordLightningMan
Upstate New York
F150
Am I the only one who hasn't pulled any fuses? It seems like a lot of DIY fixes may in fact be causing other issues, I don't want to mess with anything on my truck at all.
