- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
655 mi 2-day trip report...
Americus GA to N Charleston/Mt Pleasant SC back to Americus GA
Saw my fastest speeds yet from EA in N Charleston at 168kw for the whole 17% to 60% charging time...
I am smarter than the Ford Nav system and the truck's 'Range' indicator, too... my calculations ALWAYS
come out more generous than what the truck 'says', especially when it states that you will NOT have enough
miles... I typically always do, though, because I have calculated it correctly... it is just too pessimistic, though
I imagine Ford does this on purpose. I drive conservatively, with most miles on this trip on HWY 280 from my
home all the way to Savannah/I95 at about 55ish... up to 72 on I95 North, and 57-62 or so on Hwy17 into Charleston...
All EA stops provided GREAT charging speeds, and easy activation from the Ford Pass APP, but selecting
the 'right' EA unit is key, and can be part of the aggravating/annoying 'charging journey'... choose wisely.
Some work great, some won't activate, and some aren't operational at all... oh well. Also, with a 'big' vehicle
like the LIGHTNING, you can't always use the 'typical' pull-in or back in configuration that EA might design.
On two of the occasions, both at the Pooler GA EA Walmart location, having to use the 'other side' of the unit
made the most sense, even though the screen is on the opposite side of the unit. The last charge I had to
pull the cable completely ACROSS the hood of the truck, but it DID reach, barely... oh well. Other vehicle owners
looked at me a little strangely on both of those occasions. Oh well.
Total cost about $70 considering at-home charging costs for the first 200+ mile leg. Overnighted at a fine hotel
with no charging option, but only a mile from N Charleston Target EA units for the next morning with NO ONE else
arriving, although I WAS there quite early -7:30ish am. This may be the BEST time to charge.
Temps 45-60 average. HEADWIND the whole first day. Winds helped on the way back. Tires at 50ish all around.
This truck is SMOOTH, EASY, and Assistive/Adaptive Driving/Steering and Cruise are FANTASTIC, Especially in heavy
stop-go traffic - it manages this flawlessly. I've only got 38,500 miles, so I'll give it a few more before I know for sure : )
( I also had ProPower to the bed on the WHOLE time the truck was on, for the FRIDGE, and to be able to use the coffee
maker, microwave, and even the toaster along the way_) The 'time of travel' considers all the additional time the
truck is on even when parked.
