Android auto without wireless?
bananaslug79
Samas
"Sparky" 2022 F-150 Lightning Lariat SR
Self employed
I use mine exactly how you are trying to. Turn the "Wireless App Projection" toggle off (I need to double check the name), then AA only uses the cable to connect. I use mine this way daily.
This is the way. Wireless AA was too finicky for me so I use the wired option only.
Don't know if it makes a difference or not, but I also disabled any hotspot from the truck settings too as this seems to interfere with some connections. Bluetooth is required for hands-free calls (apparently, even using wired-only for AA).
When the option comes up on the phone for what to do with the USB connection, you have to choose "File transfer/Android Auto". If it's not one of your options when you plug in your USB, go to Developer Options > Default USB Configuration
This ☝ and the SYNC toggle for app projection turned off.
I did that, I have the options, still did not work.
Maybe I needed to shut down the truck and let Sync startup from scratch.
I edited earlier post to standardize terminology, (I paraphrased previously) transfer/Android Auto
bananaslug79
Samas
Self employed
Are you sure the cable can do power delivery/data transfer? I believe AA's requirements using a cable is different than any old USB cable. I've only found over the years to just try ones until I get one that works (usually older but still high quality cables).
Reactions: bc1
As far as I know, it's a brand new C to C cable, I'll try an older A to C.
WildBlue
Somewhere
2024 F150 Lightning Flash
I think I understand what you are asking...
If I remember correctly, there is a Wireless App Projection setting in the Settings menu (probably Connectivity), disabling that might achieve what you are looking for. If that doesn't work, you can also disable Wifi on the truck.
I'm going from memory here, sorry.
Thanks for the response. This was the fix! Much appreciated!
I used the method @Firn mentioned very early on. The wireless AA always made my phone overheat so I gave up and disabled it. Have had no issues since.
