150ish
Scott
2021 Ford F150
Inspector Gadget
Is yours on the stiffer side as well?
No not at all. Mine rides so much better than stock. But my tires have a little something to do with that. I went a little more tame on this truck. They aren't overly aggressive but still preform very well in the sand when I need them to.
Tizzzo
Tizzzo
Ed
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
Nice! What is the reason you’re dropping down to a lower height setting then?
150ish
Scott
2021 Ford F150
Inspector Gadget
My truck only went up about 1.25" after settling. I want to be closer to the 2.5" mark. Each notch on the Bilstein's is about 0.25." So if I go down to the 2nd notch and add a 2" spacer lift that should get me there. Anything over 2.5" gets a bit sketchy without adding in longer upper control arms.
Tizzzo
Tizzzo
Ed
Veteran
That's strange, I set mine at the 2.1 setting and it looks like its an exact level or maybe even a tad bit nose high as you can see on the first pic on post#25. It might just be my camera angle though.
Tizzzo
Tizzzo
Ed
Veteran
Also if you're going that route I have a ready lift 2.25 spacer I can ship to you if you don't mind dropping down to the first setting.
150ish
Scott
2021 Ford F150
Inspector Gadget
I might take you up on that offer. I was thinking that maybe mine wasn't as high because I bought it for a 2020 and they still haven't released it for a 2021 yet.
How much are you looking to get for your 2.25? and where are you located at?
Tizzzo
Tizzzo
Ed
Veteran
I’m located in Los Angeles, California and I can do $100 plus shipping cost (y)
150ish
Scott
2021 Ford F150
Inspector Gadget
I will have to pass. But thanks for letting me know.
Poalpo
Mass.
F150
Guys, what do you think about going with ready-lift 3.5 sst lift kit while also adding in bill-stein 6112 on their lowest setting. That would give 3.5 inch lift with solid high performing front end shocks. No one i’ve seen has done that, but i am wondering if there is any prohibitive reason to get it done. The kit is designed for stock shocks and springs but i wonder what could be wrong replacing it with billsteins 6112.
Tizzzo
Tizzzo
Ed
Veteran
Hey guys just to give an update on my feedback, I recently swapped out my stock 18inch wheels and 295/70/18 nitto ridge grappler tires to some raptor 17 inch take offs with BF Goodrich KO2s 315/70/17 and this new set up is perfect! Having the Bilsteins at the highest 2.1 setting meant the springs were at the most aggressive preload and made the suspension feel very firm. Not harsh at all but very firm, especially with the stiff E rated tires. Now that I swapped to softer C rated tires and the tires have some flex to them the ride feels so much better! It absorbs small bumps smoother now and feels very plush and comfortable. Both sets were at 38 psi for reference. Also at the highest 2.1 setting my truck looks perfectly level with almost no rake at all, I will try to get exact measurements soon. My suggestion/advice would be to run the 1.75 setting to leave some rake and slightly more comfortable ride as well as choosing a C, D, or E rated tire depending on how firm you like your ride with C being the softest and E the firmest. Hope this helps! For the money this suspension is awesome and I am extremely happy with the ride.
