Braking indication
mr.Magoo
2022 Lariat ER, AMB
THIS!
Brake lights will illuminate, I don't need a dash indicator for that. But let me know when I'm pushing the brake pedal too hard and the brake pads are kicking in. Long live brake pad life!
Uhm? Whenever your braking score is less than 100% you used friction brakes.
I'm pretty sure you'd want to watch the road under braking and not monitor the dash for the perfect amount of braking.
P-38
2024 Lightning Lariat
My assumption is that if the green charge measure doesn't touch the end of its space, the pads aren't used. This seems to equate exactly with the brake coach indicating 100%. I went to great lengths to prove this to myself with my plug in hybred even to measuring brake temp after a long descent. I still would like to see it.
For the most part...
But if you mash the brakes hardish on a cold (30°F) morning the Regen bar does not go all the way and you get a 61% for a brake score. I think it had to do with hard stop so no Regen ramp. Deer popped out and his buddy turned around before crossing.
