- First Name
- Brandon
- Jul 26, 2022
- Tucson, AZ
- 2022 Lightning ER, 2025 XC90 Recharge
I interpreted your previous comment as being able to run off solar as separate from the HIS. I knew the HIS had solar options (if I recall, there are several sizes of inverters that can be ordered). If I understand it correctly, from Tom's video, the HIS can pull solar to feed the sub panel but it cannot charge the truck if there is excess production. Which is kind of a bummer.The HIS supports a hard-wired (non-vehicle) battery in addition to the FCSP connection to a vehicle battery. I assume that can run in the absence of grid power, but I'm not 100% sure.
I'm also not 100% clear on the output of the HIS in the solar+vehicle configuration. I'm guessing that the maximum output is still 9.6kW, but with solar some of that can come from the panels, while the remaining demand is drawn from batteries (either hard-wired or vehicle).
