Status
Not open for further replies.
digitaldad
ABQ
'23 Lariat ER MaxTow
iOS 6.19.0 is out - performance improvements & bug fixes continue :oops:
Good!
I noticed that my departure time events were not kicking off correctly the past couple of days, or at least the Ford App didn't show the animation of the button when it should have, I manually started the truck when I thought it had missed the event.
This afternoon, I deleted all the events and recreated them hoping to see improvements tomorrow morning, I'm still on 6.18.0
jsl
James
2025 Flash
I've noticed with this update that the iOS widget is no longer working (or available). Previously I could see a dynamically updated lock/running status via a widget, which, when tapped, would open the app for full functionality.
iPhone 17, ios27 Public Beta 2
EFG
Ed
software developer
I noticed this exact same widget behavior immediately upon upgrading to IOS27 Beta, I got an update yesterday from Apple, and the problem has gone away. My Tesla App that controls my solar also did the exact same blank widget thing, it is now working as well.
JRDM2
J
2025 Lightning Flash
I didn't know there even was a widget. Added now.
ClevelandBeemer
2025 F150 Lightning Flash 131kWh
I also experienced this on iOS 27 Public Beta 2 last night. After a restart it resumed working again.
Ford F-150 Lightning Ford App 6.19.0 Released (iOS & Android) IMG_1167
BluesClues
2022 f150 lightning sr lariat
@Ford Motor Company there is a bug if you set a One-time Charge Limit before the charge rate has reached it's peak, it stops whenever you set the One-time Charge.
So if my charger is capable of 10kW, but I set 100% for one-time charge and it's only at 5.6kW before ramping up - it'll just stay there and not update the charging stats.
I dunno where you report bugs.
VIA your phones APP store, you will find contact information for each app, reach out to the folks listed
This is what is shown in the Android version of Ford App {Pass} via google play store.
Ford F-150 Lightning Ford App 6.19.0 Released (iOS & Android) 1786293417826-ig
You could also send a rating with description of your experience, they often react to the review with boilerplate responses, but that information could also alert the DEV's to figure out a fix.
Ford F-150 Lightning Ford App 6.19.0 Released (iOS & Android) 1786293618148-xj
I <3 My Lightning
There was a glitch with the last one when clicking on "Charge Station"
It would first show an image of fords other charger, then would at the last moment change up to the CSP image
Ford F-150 Lightning Ford App 6.19.0 Released (iOS & Android) Screenshot_20260811-152057-443
Extending time on remote climate start requests, often requires a FORCE STOP of the android application to allow it to process the extension request.
Status
