OtterJohn
- First Name
- John
- Jul 31, 2023
- Philomath, OR
- 2023 Ford F-150 Lightning Lariat ER
Nope, no slider on the home target charge page either. I’ll try the uninstall/reinstall (I’ve been in IT for 35 years, you’d think I’d have done that first…The missing slider on your Charging screen is weird. Searching the whole Internet for “FordPass target charge setup” there are many issues. Yours may be slightly different but here are things you might try:
When deleting charge locations make sure they show deleted both on app and in vehicle.
- Uninstall, reinstall FP app
- Delete your home location in Charge setup. Delete your Home location in the Nav settings. Setup both again. Will have to likely initiate a charge to set a “new” location.
- Same as 2 but disconnect 12V battery for a few minutes after deleting Charge location Home and Nav location Home. Then setup again.
One other thing. In the app, when you go to the Energy tab, then Target Charge > Home > do you see the text below the slider that "Target Charge Levels can be adjusted during a charge session..."
