smandel
- First Name
- Steven
- Aug 18, 2023
- Las Cruces, NM
- 2022 lightning Lariat
- Occupation
- Retired Stagehand/ Electric/Sound/Props/Carp/Etc
While not advertising the compatibility with existing solar installations, the HIS worked well with 7k of my existing solar.
Well today was the 5th time I simulated an outage with my AC coupled solar pumping out 6k of power.
When initiating the outage, my truck powered the home with .9kw and the battery level was at 89%. After a few minutes my Solar edge inverter began to operate and started powering the home without the use of the truck battery. The delta inverter started to charge the truck as well. Inside the truck the display showed 0 of 9.6kw showing no output from the truck battery. During the outage session the truck battery level increase from 89% to 92% showing the delta inverter actually charging the truck.
The only issues I have is the power surge of the motor on my well pump blinking the lights. I’ve added a power conditioner to my 4 ton AC that has made that power up smooth.
The FCSP still shows outages when there aren’t any and faulted after this session.I wanted to share a 1 minute video but the file was too large.
