Intermittent "No Audio": FIX #23
I'd call about this if it were me and was out of warranty:
https://electronicrestore.com/collections/automotive-repair-services/products/ford-acm-repair
Or look for a local shop that will do it.
I think $1200 is a steep price for that from Ford.
How to Get Started
Simply place the order and send the ACM using the instructions that will be emailed to you. If you’re unsure whether your ACM is faulty, give us a call, and our support team will assist you in diagnosing the problem.
Nylon brush and isopropyl alcohol on the apparent corrosion ~might help~
Hard to be sure from a photo, but those brown spots just look like cosmetic soldering heat related discoloration, if the pads have not been damaged, which it does not appear they have been - when the heat has damaged the board, it is usually pretty obvious as the video below indicates.
---FYI---
Heat discoloration during soldering, typically brown or black staining, indicates excessive heat, prolonged soldering iron dwell time, or flux residue, often causing charring of the solder mask or fiberglass laminate.
While often cosmetic, severe discoloration can indicate lifted pads, damaged traces, or carbonization, making the PCB conductive. Prevent this by using appropriate temperatures (350C or lower), minimizing iron contact to 2-3 seconds, and using flux to improve heat transfer.
This video explains how to identify heat damage and bad solder joints:
https://www.google.com/url?sa=i&source=web&rct=j&url=https://www.youtube.com/watch?v=Apkf6Mt9kKQ&t=22&ved=2ahUKEwjP78Xy6KmTAxUiFFkFHajSEigQ__QQegQIAhAF&opi=89978449&cd&psig=AOvVaw3TytQ9TO1HdNHK0F7QQbK6&ust=1773936050755000
Also sometimes the flux burns, and that will clean up with isopropyl alcohol as suggested above.
But really it is just cosmetic.
2wheeltraveler
Austin, TX
2022 F150 Lightning Lariat Rapid Red
It may be your other post I commented on, but I have had the exact same issue. Sound stopped, same situation for radio and GPS. Started working randomly after several days and stopped again.
Currently in shop, got text today that they are replacing the radio.
I hope you weathered the storm well! We were in Maui last week and had fantastic weather. Left last Thursday night and it had rained all day but we missed the bulk of it. Was devasted to see what the next few days brought. The flight home was very rough… lots of “floating off the seat” moments 😳
  • Wow
Reactions: chl
DiveMan911
DiveMan911
R.J.
Maui, HI
'06 Acura TL, '13 Ford Escape
Flight Nurse
After going through all the steps in the WSM, looks likely the ASM.
Local dealership says $390 for the part, +$50 freight (Island Life)…so I told them to order it. There is a $150 core charge, but will happily give them the busted on.
🤞🏼 this will be the fix.
Yeah, it was quite a storm. 30 inches of rain in Kula…17 down here in Kihei…in just 24hrs 😵💫.
We had a lull and now expecting another couple of days of rain from another storm passing though. Glad you enjoyed your stay and the weather was nice!
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
Seems we’ve reached the conclusion to this saga. The ACM was replaced today, and it appears to have rectified the problem. Audio works and all DTC’s are cleared.
interestingly, the cheaper price was because this was a Ford remanufactured part (manufacture date was 2022). I peeked inside the aluminum shell and could see new solder and flux around the same area (silicone chip) as my busted one.
blb228
Brett
2024 Flash Agate Black
I'm going to add my experience and codes to this thread instead of starting a new one as I believe it relates/is the same issue. (moderators please update or move if necessary).
The issue I'm experiencing: crackling or a pop from the speakers followed by silence. No audio works after this happens from the audio system (no bluetooth audio, FM/AM, Satelliete etc), I have tried sync resets, pulling the 12v battery negative cable for 15 minutes, pulling fuses etc. Nothing seems to remedy this except..... time/heat and/or moisture dissipation - could be several hours or a day or three before audio starts working again. This has occurred five or six separate times now over the past 8 months. It happened three times alone last week with a hot and humid heat wave in central PA.... It happened both a few minutes after driving and 40plus minutes after driving another time. According to my local Ford Dealer- the codes being thrown in the ACM module are B1511 and B150C.
