Ionna Chargers Rip!
ClevelandBeemer
2025 F150 Lightning Flash 131kWh
So I used to think there wouldn’t be much of a difference between a Tesla V3 Supercharger and a beefy CCS1 DC fast charger but wow was I wrong.
I had the opportunity to charge at an Ionna 400kW today and damn do they rip. I was able to charge from 20% to 80% in 35 minutes, holding 124kW all the way to 80%. This charger was also totally exposed and in direct sunlight yet the cable and charging socket didn’t feel warm at all.
Conversely my last few V3 Supercharger sessions were less than stellar. I had one session where charging derated to under 100kW in less than 20 minutes. I suspect the charger cable and/or the A2Z adapter was a large part of the derate as both were toasty.
I’ve been going to Superchargers because they are abundant and seem to be less expensive but I’m starting to think it’s worth paying slightly more to use a beefy CCS1 DCFC.
Ford F-150 Lightning Ionna Chargers Rip! IMG_6881
Ford F-150 Lightning Ionna Chargers Rip! IMG_6879
Ford F-150 Lightning Ionna Chargers Rip! IMG_6885
swajames
CA
That's tremendous. Not many of these out west but one is opening up not far from me soon.
K6CCC
Glendora, Calif.
Where are they opening one here in CA? PlugShare says one is coming in Inyokern, but no sign of construction as of a few weeks ago. I will be there in just over a month.
swajames
CA
Their website says one is "opening soon" in Vista. Site says 4 NACS and 6CCS.
K6CCC
Glendora, Calif.
Cool. Last PlugShare check in was 20 Aug. and the report is that the construction fence is down and it looks very close to opening.
kstype
Kurt
Pennsylvania
Principle Systems Engineer
iONNA is doing some great things across the country - Lightning Clubs of America has been coordinating with them on meetups and participating in ribbon cuttings are various locations.
The Alpitronic gear they are deploying is high-quality and robust - they also like to install canopies wherever they are able to, which should add to their lifespan. I am looking forward to seeing how well it holds up over the next several years.
Ford F-150 Lightning Ionna Chargers Rip! IMG_0698
Ford F-150 Lightning Ionna Chargers Rip! IMG_0557
Ford F-150 Lightning Ionna Chargers Rip! IMG_3039
davehu
hot springs, AR
I used one in Plano TX a few weeks ago. Went from 36% to 77% (56kw) in 26 minutes. I think that equates to about 130kwhr if I'm doing the math. I haven't done a lot of fast charging but it seemed pretty good. ford plug and charge worked as advertised
ClevelandBeemer
ClevelandBeemer
Ahhhh this reminds me, plug and charge didn’t work for me. I have to enable the charger via the Ford app.
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
Love IONNA - and since they're in the BlueOval Charge Network activation is easy with FordPass.
Same hardware is also being deployed by other networks - like Mercedes-Benz and bp pulse - also both BlueOval Charge Network members!
