Charger Usage “Spike”
M4rked1
Tim
New Hampshire
2022 F-150 Lightning Lariat, 2007 F-150
I’m not sure I’d trust your utility data, either. Why is July zero?
not sure what’s up with that honestly. It certainly was not zero.
You may have also had a meter read date change. So for example one bill is 15 days and another is 45 days if they changed you from reading on the 1st to the 15th. Could also explain why July is zero - that chart is just showing raw bills for that month.
You need to pull each bill, look at the start and stop dates and divide the billed usage by the number of days in that bill cycle. This gives you average daily usage. Now see if your daily average changed over the May-Sep time period.
is truck mileage logged anywhere we can access? Just to “prove” I didn’t take a bunch of day trips :) ?
No, but nerds like me keep spreadsheets with weekly miles driven and KWH consumed by the FCSP, which ironically is not always accurate, often have missed records when the FCSP and the Ford cloud refuse to communicate with one another, my Emporia Vue2 energy monitor is flawless measuring and cloud recording every kWh of energy I have used.
Is it possible your total home energy was higher in May 2023?
We had a mild winter in New England, so I wouldn't expect you did, but that's a possibility.
M4rked1
Tim
New Hampshire
I don’t think so.
honestly there is likely no way to put the pieces together at this point. I will keep an eye out to see if it occurs again and hopefully catch it before half a year passes :)
Refactoringdr
Don
Albion, IL
F-150 2023 Lightning Platinum (ER)
If the FCSP loses its server connection, it takes days to reconnect (often a power cycle). When it does it often bundles all of the charges since it last reported into a single day. I have seen it several times.
