Keyless keypad stuck in lock only mode
dandeliongo
Daniel
Tacoma, WA
2024 Ford Lightning Lariat XR
sales
So I went to open my frunk with the keypad and the doors locked when I pressed 7, which happened to be the 4th digit in my code. So I thought I messed up and tried again. Googled it and found that if you enter the code too many times it goes into this mode. But only for 15min or by using the app to unlock the door. Didn't work.
Next it said to reset the pin. Which was a pain. Figured out how to program a new keyfob in the process. Nope didn't work.
Next was disconnecting the 12v battery, but I read that disconnecting the battery may cause other issues. So I did something that supposedly made the truck charge the 12v to 100% and was supposed reset everything like I disconnected it. DIDNT WORK!
So what happens when you disconnect the 12v battery? Explosion?
Any other suggestions?
There’s no downside to disconnecting the 12V battery.
Not securing the connection properly afterwards is a concern with home mechanics. There is also this:
Note: Make sure the vehicle has been
switched off and doors closed for at least
five minutes before disconnecting the 12 volt
battery
dandeliongo
dandeliongo
Daniel
Tacoma, WA
sales
So it was a bad keypad. Apparently when you pushed one button it registered all buttons at once. Had to take it in for recall anyways, which ended up being 5 recalls. 1.5 days later. Don't recommend taking your truck in for a recall the same day as someone else does
