Looking for fender NMO Antenna mount
  • Thread starter Deleted member 15218
  • Start date
  • Watchers 2
Guest
This message is generally for amateur radio operators. I'm trying to attach a 2M/UHF antenna to my 2023 Lightning XLT. A mag mount is a no-go as it won't stick to any surfaces. DX Engineering and others make an angle bracket that attaches to a 10 mm bolt on the driver's side finder. I just looked carefully at that area and I found the bolt but there is a plastic channel that comes right up to the bolt with a cable running through it. I guess that's so the frunk can be opened via the fob.
Any hams out there? How did you mount your antennas?
73,
Al, K7AR
Vancouver, WA
queuewho
Western PA
22 F150 Lightning Lariat SR
Not a ham but I have been playing with meshtastic stuff lately... A few people have posted the bulletproofdiesel.com third brake light setup. Seems like a good option, though you won't be parking underground or in structures with it.
Guest
Thanks those look like well made products but expensive. I'll consider it.
Al, K7AR
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
Guest
Thanks Price that's a great tip. I didn't think about cutting back the plastic trim. Have to be careful with that wire running thought it. I'll lookup the parts you used.
73,
Al, K7AR
TheSilverFlash
Paul
Diamondhead, MS
25 Flash
I used the Comet/NCG vehicle specific mount FO4ANTNCG-R (https://www.dxengineering.com/parts/cma-fo4antncg-r) paired with a Comet CK-3NMO cable assembly (https://www.dxengineering.com/parts/cma-ck-3nmo5)
I chose the passenger side variant as the Ford up-fitter guide recommends not installing amateur radio antennas on the driver's side fender.
As you can see in the photo below I had to remove the trim around the edge of the frunk, install the antenna mount and then reattach the trim.
How did you run the coax into the cab?
