Status
Not open for further replies.
WoodduckMN
Jeff
Andover, MN
23 Tesla Y, 22 Lightning Lariat, 21 Chevy Bolt, 13 Ford Explorer
Manager
Yes, they are EV. Toyo now list three sizes as currently in production but these I could find only at simpletire.com
I don’t see the EV tire on the simpletire website only the E version with is not the same as the EV version.
When I called Discount, he said he found 2 in stock in CO and two more on back order. I think he was searching TireRack inventory. Stock definitely is low and/or dwindling.
Magendi
Philly area
Lightning Lariat
I just checked and simpletire still has them. Their search feature isn’t the best but if you search by size then filter by brand the EV tires are there.
MO Lightning
Jeff
Springfield, MO
2022 Lightning Lariat - Smoked Quartz
Greetings Friends!
I just got the new AT3 EV tires installed yesterday. I went with 275/65/20 (allegedly the last 4 Discount Tire could find in the country!) on the stock wheels. Out the door at a bit over $1800, installed.
Also had the RC Level Kit installed at another shop earlier in the day. ($300 installed).
Overall, front wheel well height is about 3" higher.
Trip meter said I average 2.1 mi/kwh in the 2500 miles before the swap, and I am at 2.0 mi/kwh in the 80 miles after. Will keep an eye on it over the next 1k miles and report back.
Speedo is off about 3% @ 70mph, so slightly skewing the efficiency numbers.
No issues with Blue Cruise. Works just as bad on my highways as it did before.
Running 50psi for now.
Tires are definitely louder. Probably proportionally the same as when I put the BFG KO2's on my old F-150. Not distracting, just different.
Greetings Friends!
Interesting, I'm trying to get the 275/60/20 for mine. They said there was 2 and had to wait for another 2 on back order. Quoted same price, but haven't gotten a call that they are in yet. Guess I need to reach out and see what's up. Starting to have second thoughts due to the price.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
For what it's worth, a local dealer had a set in their warehouse. I sent them the tire rack link and they beat the price by about $40ea and had them installed the next day. Might be worth reaching out to your dealer(s) to see if they can get them.
mdlightningIL
Martin
2024 Ford F-150 Lightning
Insurance
Any thoughts on the E, SL, XL, LT versions of the Toyo Open Country AT3 EVs? LT is a stronger tire, but I won’t be rock crawling or towing much. Just light off-roading on dirt trails. Camping with a bed tent, etc. Been getting real confused with all the versions of this tire. Is the XL 116T I’m seeing advertised now the same as the SL? And LT the same as E? Any and all advice/info is welcome. About to get some of these and trying to see if I would be good with the 275/60R-20 116 XL.
mdlightningIL
Martin
Insurance
Rockin the new 116T XL direct replacement for OEMs. Not the E. Not the SL. Same PSI. Same TPMS. Ford dealer will install for you whether you get them from parts or another source. So far, can feel more grip but nothing too crazy. Same ride as OEMs, which was a big deal for me. Ate snow today like a beast. Looking forward to seeing how these things go. Anyone else rolling the 116T XL, shout! I’d like to know how they are working for you.
Ford F-150 Lightning Toyo Open Country A/T III EV Tires Launched: Charge Up Your Adventure IMG_4968
Ford F-150 Lightning Toyo Open Country A/T III EV Tires Launched: Charge Up Your Adventure IMG_4952
Status
