ctuan13
- First Name
- Chuck
- Jul 31, 2022
- Pittsburgh, PA
- 1979 Continental, 2022 F150 Lightning, 03 Marauder
Was doing some in depth interior detailing of my truck before I depart on my cross-country road trip and removed the door sill trim to get all of the dirt, sand and dust cleaned up that had worked its way underneath. In doing so, I discovered something very concerning: Due to an inherent design flaw/oversight, there is pretty sizeable gap between the interface of the curved footwell trim and the flat door sill trim.
Any time water or in the rust belt during winter, salty brine, drips onto this transition zone, it will easily find its way down below. Right below is where one of the main body wiring harnesses runs and there is an enclosed channel along the cab that runs all the way to the rear. There isn't really a way for water to escape once it's down there and thus it'll just sit there until it eventually evaporates.
Despite the frequent misconception, aluminum does corrode, just not usually in the spectacularly destructive way steel does. Well I could see clear evidence of early corrosion as the paint began had already begun lightly bubbling down below. And out of an abundance of caution, because I almost couldn't believe it was all coming from this single point of intrusion, I searched and checked for leaks everywhere else and missing or leaking floor grommets, but it was obvious from the salt residue patterns where the liquid was coming in.
So naturally I wanted to clean it all out and remove the salt as best I could, so I removed the footwell trim and attempted to unclip the brackets holding in the harness. Probably don't do this unless you wanna snap the plastic like I did. I was able to secure them back together with zip ties, but you might have to just try and work around the harness with a fine tip adapter with your shop vac. For me, I used a very damp (dripping wet) microfiber cloth soaked with water to thoroughly dilute and soak up the salt in the area. Once it was cleaned, I dried with a shop towel, I followed up with a quick wipe with ONR (Optimum No-Rinse) wash + wax.
What was my solution? After I reinstalled the footwell trim and zip-tied the brackets back together, I added a small piece of seal closed-cell adhesive-backed foam to that particular low spot in the footwell trim. While I'm sure it's not perfect, it seems to take up 95%+ of the gap, so I'm happy for now!
TL;DR: Design flaw in floot well, door sill trim interface allows salty water to get into a void underneath where it can't easily escape and can lead to corrosion. Problem solved remedied with a piece of adhesive close-celled foam.
