Raising tailgate by hand?
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
I sometimes raise my tailgate by hand. Am I damaging anything by doing so? My brother had to repair his Tesla Model S liftgate and was told that he had caused his problem by lifting it by hand, forcing it against the motor. When I lift my tailgate I am forcing it against its motor.
The Weatherman
South Central KY
I don’t do that very often, but I have lifted it by hand. What I have noticed is that it seems to relax the motor assist when I lift it faster than the motor itself does.
Short answer. I don’t think so.
There is a setting in the center stack to turn the auto lift off. If you’re going to do this more often then not, it’s probably a good idea to turn that off.
Not necessary.
Manual Close
You can close the tailgate manually when you lift the tailgate in a continuous motion. If you stop the tailgate motion, the lift-to-close feature engages and power closes the tailgate.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
I will add that I often close mine by hand cause I forgot I bought a princess truck.
The only thing I have noticed it it seems the computer forgets it is closed sometimes and when I do use one of the various buttons to open it, it “latches” it first then you have to press again to have the motor release.
Whistler
2024 F150L
I close mine by hand 99% of the time just from muscle memory. I never deactivated anything, it works either way.
