Remote Start from Key Fob - It Works!
astrand1
Alex
Studio truck driver
Search programyourremote on eBay and type in your FCC number. I bought one from them for my 24 Flash, It is OEM, decent price, and programmed the first time.
If we are allowed to post links I can do that.
If you have issues finding the store let me know and I can PM you.
Links are fine to be posted. I tried and got nothing. I must be half a retard. ? (because you never go full retard!) anyway if someone can link to an oem 315mhz key fob with the remote start button id appreciate it.
PJnc284
Garner, NC
AK018118 Aftermarket 315/433.92/434.26/868/902MHz 15K601 For Ford Mondeo Fusion Smart Remote Key 49 Chip M3N-A2C31243800 - AliExpress 34 #4 works for my 23. It has a trunk icon instead of tailgate but lock/unlock/remote start and tailgate works. One thing that got me is that you have to hit lock and then press the remote start button twice. My ram just requires you to press the remote start twice.
astrand1
Alex
Studio truck driver
mxracer
2024 F-150 Lightning Flash
Damn..must not have that frequency. Maybe message him... he's got a real business down in Tampa
GarageMahal
JT
Minnesota
Data Wrangler
Anyone find one that can also open the frunk? I use that button a lot.
astrand1
Alex
Studio truck driver
I don’t think it exists. That button is where the remote start button is. I use my frunk a fair amount but I don’t even carry the key sometimes since I have PAAK. I just use the button for the frunk.
dcshoes23
I found one using the FFC ID number on ebay that is for the 2020-2024 Ford Transit and it has a 'trunk' button on it along with the remote start - I just ordered it so I don't know for sure if it will work with the Lightning Frunk. I was $37 with tax and with free shipping.
When I get it I'll program it to the truck and test it to see if the Frunk button will work.
link: https://www.ebay.com/itm/306388362552
UPDATE: well I programmed it but...the doors work, not the Frunk or what I thought was the remote start - turns out it was a button for side doors on the transit, alas.
I tried several sequences of lock unlock remote start button (side doors) that would work with an ICE and eTransit, no go.
Guess I'll just order one with remote start button and leave it at that.
ryun
Earth
Would be cool if you could repurpose the useless alarm button on an existing fob to do... anything else.
I decided to buy the $100 remote start add-on kit form KickyRide:, and with it I can use my original FOB.
https://www.amazon.com/Plug-Remote-Start-F-150-Trucks/dp/B0C9XDXFT1/ref=sr_1_15?dib=eyJ2IjoiMSJ9._iEoBX5a1IJU0BJ-smX6Fce4Nc5TW46EWpXbTaVIdLiVOMCCICrXvqV4Os107oGnra9kfrGsQ0fj6kCwQU6mJmnkn31AM3TSQreILIBhfw8yBOTK-i1a4gpUYXFvV81LL9_Y52KeerZajnqAbs9Sop1yF0u8sPlCG-n5OXmnVkaBwdvjH8Q6gX67z4pdQ-ygyvKgKF9jEZ1-eE2-u-dqeYJIibQTjyVKRt1dPNVKS3YrGpS7Mh93bQzNJqislVysCVBLAJ5K_aEVIjVvwe4k_d5rIxOe8vapgDraAeUXR4Y.LWlQpXaW9LAe8Hb-LbVXsM1Gw3ASRlCz5Q8PRpmUW44&dib_tag=se&keywords=remote+start+ford+f150&qid=1773620421&sr=8-15&th=1
I contacted the company and they confirmed this unit will work with my 2023 Lightning.
Plug-n-play with the only wire one has to attach separately is a ground wire that comes with a ring terminal for easy attachment to a nearby bolt behind the glove box.
Install video (an ICE truck but company confirmed it will work with the Lightning and a push button start):
https://www.amazon.com/vdp/0bb9ed24154d4dc4afdd509d94bca661?ref=dp_ive_hero_0
UPDATE: well I installed and programmed it, but did not work, so I am contacting the company for a tweak...may have something to do with the fact that there is no hood per se so no hood ajar signal.
UPDATE 2: well actually it may have worked - the remote start won't turn on everything according to the manual:
The direction indicators flash twice.
• The parking lamps turn on when the
vehicle is running.
• The horn sounds if the system fails to
start.
• All other vehicle systems remain off
when you have remotely started the
vehicle.
• The vehicle remains secured when you
have remotely started the vehicle. A
valid key must be inside your vehicle to
switch the vehicle on and drive your
vehicle.
So it did flash the lights twice - I thought the truck was off because the screen did not light up inside the truck.
Native Images
Puget Sound
2025 f150 lightning lariat extended range
I read the posts in this thread. Followed the directions. Bought a 2025 raptor key with same frequency as then2025 lightning, followed YouTube video. And tested. The results are the raptor fob preheats cab but the remote start function says I need to push the start button upon entering the truck to start the lightning. Is this how the remote start function works? I thought it would remote start the truck like any remote start key fob. Am I missing something? Thank you.
Astrotrain00
Corey
Linden, MI
2025 Ford F-150 Lightning Flash
I bought this off of Amazon for my '25 Flash: https://a.co/d/0iNwm2fB
And then followed this YouTube tutorial:
It took about 3 minutes and works like a charm.
When I get into the truck, I still need to put my foot on the brake and press the start button. That is the same way my Honda Passport worked and my Hyundai Santa Fe before that. Even if started via fob, you still need to turn it on when you get in to fire everything up.
Hope that helps.
The missing part is since you don’t have a ICE truck, there is no need to start the truck to get climate on. The fob starts climate just like doing remote start from the app.
Get in truck and press Start to drive. Interestingly, no need to press brake on remote starts.
