Rotary dial mod spray paint color
MUSTANGMICHAEL
Michael
Wisconsin
23 f150 Lightning XLT
I’m curious if anyone who has done the modification to the rotary shifter has successfully painted matched the mount to match the cup holders color? If so would you mind sharing a pick and the color name? I get that it’s black, but there are so many different blacks with different finishes. Just looking to save some $ and time by hearing what has already worked. Thank you in advance!
Old Aviator
Larry
WPB, FL
Consultant
1 can of each sufficient?
molsonmatt
Matthew
New Jersey
2024 Lightning Lariat
Do mutliple layers of filler primer to smooth out the 3d print lines. I got the similar brand of trim black but “ultra” thinking is more durable but it was a satin and looked really cheap and too glossy. Went to the matte and the match is pretty spot on.
Old Aviator
Larry
WPB, FL
Consultant
Sand smooth? What grit? how many coats?
molsonmatt
Matthew
New Jersey
You can sand in between primer coats. I don’t know if it’s totally necessary. Just Use a fine grit between the last primer coat and the black paint.
astrand1
Alex
Studio truck driver
What about an adhesion promoter? I’ve been reading about guys who have used that product. Wonder if it’s necessary.
