- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
You did not mention if you had tried "re-calibrating" the frunk - I think there is a YouTube video about this. I think you have done 3 and 4 of this list already to no avail but maybe try the reset process?
Good Luck.
1. Reset the Frunk Opening Height
This procedure can resolve issues where the frunk doesn't open or close fully.
2. Perform a Hard Reset
This method resets the system and may clear minor electronic faults.
3. Check for Obstructions
Obstructions can trigger the safety latch, preventing the frunk from closing.
4. Seek Professional Help
If the problem continues after trying these steps, a dealer service is the next step.
Contact: your Ford dealership to have a diagnostic scan performed.
Mention: any known recalls for the F-150 Lightning frunk, as a recall recalibration may be available.
This was one time the AI search seemed to have found some valid info, go figure.
Good Luck.
- Open: the frunk fully using the button on the frunk itself or by pressing the button on the dash or key fob.
- Manually: lift or pull the frunk lid to its maximum open position.
- Press and hold: the frunk's "close" button for several seconds until a tone sounds, confirming the new fully open height has been set.
- Open: the frunk completely.
- Disconnect: the negative terminal of the 12V battery.
- Wait: for at least 10 minutes before reconnecting the battery.
- Manually: close the frunk by pressing it down firmly until it latches.
- Attempt: to open and close it normally using the cabin button.
- Inspect: the frunk and latch mechanism for any debris, dirt, or objects that might be interfering with its operation.
- Lubricate: the latch components with an appropriate grease to ensure smooth movement.
- Ensure: the frunk lid and latch striker are properly aligned.
