jerock
Jerry
Kansas
F150 Lightning
This is in my garage & prewired to a subpanel for a 100 amp circuit & Pro Charger. The pro charger will be wired in when it arrives. To the left is a inlet for 240 30amp from the truck bed that goes back to the main panel with an interlock to power my house.
The second picture is a 14-50 outlet just below the electric panel, that will be used with the mobile charger. This outlet is in my shop. I can change it out later if needed for a 48 amp charger.
Ford F-150 Lightning Show your Lightning's home charging setup! IMG_3057
Ford F-150 Lightning Show your Lightning's home charging setup! IMG_3058
PV2EV
Nice. One note; Pro Power does not work with an interlock. You will need a generator input like this: https://www.amazon.com/gp/product/B00V4NDFPY/ref=ox_sc_saved_title_5?smid=A1T1R9Q3ML5YGI&psc=1
jerock
Jerry
Kansas
F150 Lightning
The Pro Power doesn’t use the interlock only the 30 amp return circuit
jerock
Jerry
Kansas
F150 Lightning
My electrician says he’s wired many generators with neutral bonds this way without any problems. Guess we shall see
SeanOC
LINY
ā€˜18 Raptor ā€˜21 Tesla Model Y
Pilot
I love the setup and I’m genuinely curious as to how it all works for you. Let us know
Kevin22
Kevin
Southern California
Chevy Volt
Systems Test Engineer
I found out on the www - world wide waste of time that you can actually power an F-150 Lighting with chicken poop! It was on the internet so has to be true. So I got me some chickens and yes that is my automatic door. Can’t have my power getting stolen or eaten?!?
Ok here is my real system. Watch out for SunRun. They take forever and they are clueless about almost every step of the process. We had 17 panels and 2 Powerwalls installed. We also have 20 circuits running off of the batteries from a new sub panel in case of a power loss. A regular electrician installed the Ford Charger. SunRun did the rest.
Ford F-150 Lightning Show your Lightning's home charging setup! 15181A94-B4D7-48E3-A5E4-32D6147CB2BC
SeanOC
LINY
Pilot
I'm assuming the ford charger is not wired to power your house/charge powerwalls?
BzzzzztZapPow
21 Explorer Hybrid, 18 Fusion Hybrid, 22 Lightning
I received a call from my SunRun subcontractor today to schedule installation of the Pro Charger. They said "You are getting your charger on June 27, right?!" Uhh...am I? I have no idea. SO, I am scheduled for the day after its alleged arrival. Communications on the charger has been atrocious. They are in trouble once production is scaled up. I feel like they will get better, but still behind the truck deliveries.
Gerrard155
Colorado Springs, CO
2024 F150 Lightning
What is the Tesla box under your breaker panel (bottom left of photo)?
Kevin22
Kevin
Southern California
Chevy Volt
Tesla Powerwall Gateway is an electrical panel that connects and communicates between the Powerwall systems, solar panels, and grid. The Gateway acts as the brains behind the battery control system.
Ford F-150 Lightning Show your Lightning's home charging setup! CBA785D7-633C-4C56-9868-28DEC53C6478
Kevin22
Kevin
Southern California
Chevy Volt
Even though SunRun sucked installing our system (no knowledge, no schedule, terrible communication) we love it. I just charged up my Chevy Volt this afternoon for pretty much $0. The batteries keep me off the grid when charging.
kWfart
San Diego
2022 Lightning-ER Lariat
Lightning on the way 6/30-7/6. Currently have Clipper Creek dual charger for ID.4 and MME. I will have to park in driveway due to entry in garage for truck is narrow. I have a 3D printed cord protector for garage closure as I will have Sunrun install charge station pro outside for truck.
Ford F-150 Lightning Show your Lightning's home charging setup! 00FF62AC-AF99-4583-AF88-3B6CDBCA7873
Ford F-150 Lightning Show your Lightning's home charging setup! 8D26140A-C943-4D72-B51E-4C54274337E5
Ford F-150 Lightning Show your Lightning's home charging setup! FD106B81-317E-43EA-8ACE-0962F8425AC3
