toll pass sticker issues?
wingfiry
Ryan
Cleveland, TN
2023 Lightning Lariat ER
Has anyone had issues with a toll pass sticker not reading on the lightnings? I've got a Peachpass sticker (GA) and it doesn't seem to be reading through the windshield on my Lariat ER.
Crilly
Dale
Hartford wi
2 Mache GTpe
In the black aeria. That is where it has to be mounted.
wgatkinson
Bill
richmond, va
2023 F150 Lightning
I had the same issue with my EZPass when I first got the my truck. I had mounted it in the dark area of the windshield. I had to move it to the area that wasn't darkened. This fixed the problem.
Sapper55
Frank
Canton, GA
Farmer
I have the PeachPass sticker on my Lightning...I elected the sticker that is placed on the headlight unit and not the windshield. No issues so far
jbw
jeff
F150 lightning
ceo
i've had that happen in Illinois. seems to be from electronics on front windshield.
i got a transponder that is mounted on front license plate and no problem
FYI, the dark area (actually a collection of black paint dots) are called frits. They have nothing to do with electronics or antenna reception. The ones around the rearview mirror serve as glare reduction.
We have several vehicles with TollTags (incl. Mach E and Lightning) and they are all in the rearview frits area with no issue. So it could be other things causing issues but it shouldn't be those paint dots. Our toll authority recommends installing 4" below the windshield away from metal edges.
Reactions: GDN
At least as far as the Mach-E is concerned, this isn't correct.
The Mach-E windshield is IRR, infrared reflective, and will NOT allow signals through EXCEPT in the two black areas.
I was replying to the poster who implied the black areas were the issue. My point is that they are not and that is where we put all our tags including the Mach E.
brewski
GA
2023 F150L Platinum
Yes
My peach pass is in front of the mirror just below the black area. Works fine.
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
Can one of you post a picture of your pass mounted where it works fine? Should be receiving my EzPass one any day now and would appreciate seeing where it can be mounted without interfering with all the other systems in the vehicle.
What I like best about our Tollways here is that they will match license plates to your sticker and bill you that way. So - I don't have my sticker on the window at all. I keep it handy in the console, because it must be read for airport access, but the other booths they'll match the tag. They send a letter once in a while noting that my tag hasn't been read and it may need to be adjusted, but they haven't cut me off. So far I refuse to put that ugly orange and blue sticker on my truck. They have cooler ones, but I'm not paying them $20 for one.
captcory
cory
sw florida
'23 FORD Lightning PRO, honda pilot
Yes I believe it's the same in Florida "sunpass". if you register your tag with your pass it will bill you either way. The transponder would not work on my Tesla model S windshield but the tag reader would make up for it.
wingfiry
Ryan
Cleveland, TN
That's where I have mine currently (pic attached). However, on a FL and NC trip, I got toll violation notices in the mail. I called PeachPass support, and apparently my charges are being logged by Plate pictures and *not* the transceiver.
I've ordered a new sticker and will try mounting in the black area.
Ford F-150 Lightning toll pass sticker issues? 20230818_102526
