Tonneau Covers - Recommendations and Reviews
Plattypuss
PA
2021 F150 Platinum PowerBoost Rapid red
Add another vote for the x4s. If you truly want help, I think you should list your budget and priorities. Example I was dead set on hard cover for security, no drain plugs, mostly weather proof and reasonably easy to take off. Budget was around 1k. I’m happy with my choice after narrowing it down to the x4s and leer.
houstongoose
houstongoose
Aaron
Houston
2021 F150 Lariat 3.5 EcoBoost FX4
Analyst
thanks for your input - narrowed it down to Bakflip MX4 and Leer HF650. Thought I wanted a soft cover but others on this thread have convinced me otherwise
Plattypuss
PA
You’re welcome. Both are pricey but should last a long time. If you go Bak, you should reach out to frank, @Stage3Motorsports who is a forum sponsor here and can get you a good deal.
Maljr1980
Colorado
2021 F150 Lariat FX4 Sport
Project Manager
I recently picked up the Truxedo pro x15. Paid $140 from AmericanTrucks.com as an open box item, missing the hardware kit (clamps and weatherstrip). Paid $26 on Amazon for replacement clamps. I couldn’t be happier, looks great. I plan to add the Truxedo elevate t-slot rails to keep a low profile look and allow me to add crossbars.
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews 8BD16086-F4C7-4686-A150-D2185306069B
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews B9A8A7DF-1A82-49AA-8A07-77FD6B930898
GFDF150
Jerry
New Castle, DE
2021 F-150 XLT, ‘20 Fusion SE Hybrid, ‘13 Explorer
Marketing Manager
After a lot of research, I decided on the Undercover Armor Flex. It was fairly easy to install and is waterproof. I’ve had it for about 4 months and really like it and I think it looks great. I got it through Tonneaucovered.com.
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews 377B04A5-6B63-4062-8C73-50AD919E0B8D
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews 78B8F12D-C11C-41A4-BCE3-A1812C1C742D
jj4567
United States
2022 F-150
I have the UnderCover Armor Flex Tri-Fold and would recommend. I have full access to the bed, zero leaking so far in 6 mos of use. Also very secure and supports quite a bit of weight (I can stand on it). I also like the Line-X coating on the top for durability. I paired it with the Adarac Pro Aluminum rack for the necessary tri-fold clearance (due to the vertical vs. tapered supports) - all works great.
Do the Adarac rails (sides of the bed) push water back towards the tonneau seals? Do the rails make it more difficult to open your tonneau? I’ll only use my bed rack s few times a year, so I’m curious if the permanently installed rails get in the way for everyday tonneau usage.
Mr. Zog
Colorado
2021 F150 XLT Sport 3.5L EB, 5.5' Space White
The rails don't cause any interference or water ingress issues. The vertical rack "towers" do interfere with the seals on the sides of the cover when opening the cover, but it just takes a little extra force to push the cover segment past the tower (if that makes sense). I think they look a little odd, but function really well. I also noticed a rattle inside the tower rails (horizontal bars across top of towers) - it's a little annoying with the rear window open, but not a mechanical issue. I will probably just mark the tower positions and take them off when not using them - just two bolts each.
TailoredSouth
JM
MS
2022 F150 Platinum, FX4, Powerboost
Real Estate Developer
Do the trifold covers interfere with the auto close tailgate feature?
Pelican
Ohio
2021 F-150 Lariat (502A) Supercrew 3.5L EcoBoost
CPA and Rental Real Estate Management/Owner
Mine does not interfere. I have a 2021 Lariat with the auto tailgate and the LXP tri-fold hard cover from Truck Gear By Line-X. It's expensive, but I needed the added security to so I could leave my tools in the truck bed at all times. The cover comes with an end-to-end lifetime warranty. Best of luck deciding on a cover. It's not easy, but I'm sure you'll be happy with whatever you choose as they are all built well now a days.
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews Resized_20220207_200151
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews Resized_20220207_200227
Ford F-150 Lightning Tonneau Covers - Recommendations and Reviews Resized_20220207_200142
kb2755
Ontario, Canada
'22 F-150 XLT 302A Sport
+1 for Truck Gear and the lifetime warranty. I went with the Stealth because LXP was severely backordered and am very happy with it.
I don't have the power tailgate, but I do find that it seals tight enough to prevent the tailgate from releasing fully when using the key fob. Have to give it a little nudge to release all the way.
Mr. Zog
Colorado
I highly doubt it as there is no interference with the tailgate - but I can't say for sure as I don't have that slick feature :)
RedundanT
GB SA3 4EN
2021 RCSB 5.0
Making lego parts for new vehicles
Had that cover on my '17 it was top shelf. Noticed on the interstate this weekend my X4S is 'lifting" towards the front, going to have to uninstall and start over to see what I did wrong. Starting to HATE the Bak X4S.
Pelican
Ohio
Sorry to hear your covers giving you trouble. Hopefully, it just needs squared up and clamps retightened. Good luck
2024 lightning flash
Just adding that the Weathertech alloy cover now comes with finished sides. I ordered last week and received yesterday.
NeighborGeek
Steve
2025 F150 Lightning Flash
I bought the RealTruck Truxedo TruXport (GEN 2) Soft Roll-Up Tonneau Cover, via the Realtruck rep here on the forums. Having never had a tonneau cover before, I have limited experience with others to evaluate mine. I do know that my friend's cover always looks taut, while mine seems like there's a little extra slack in it. When I roll the cover out and velcro it to the side rails, I can pull the cover down past the velcro some, but obviously have to attach it to the velcro. I'm guessing that's probably an install issue more than a product issue, so this spring I will loosen the clamps and try adjusting the rails just a bit further apart to strech the cover more.
I've also noticed a little bit of water gets in at the head end of the bed, just enough that I see wet drip lines running down the head wall inside the bed. Very minor, not enough to get anything wet inside the bed, and also probably as much an issue with my install as anything.
