Turn Signal Lever sticks in the up (right signal on) position
scruvs
2023 F-150 Lightning XLT Standard Range
Does anyone have an issue with the turn signal lever sticking in the up position after turning on the right turn signal?
It's hard to describe, but my turn signal lever operates like butter when I turn on the left turn signal and return to center. Or, when I turn on my right turn signal by moving the lever from center to up. But, if I try to manually turn off my right turn signal by moving it down to center from the up position, it is more resistant than any other movement. Also, it's most resistant the first time in a drive that I move the turn signal lever to center from the up position, and less resistant after recently using the turn signal lever.
I'm wondering if it's an issue with lubrication under the steering column, but I'm not sure if that's even a thing.
Asking because I'm at 30k miles and wondering whether to complain about it before warranty expiration.
trev5150
Trev
Pilot of pilotless things
I’m only at two years and 18k miles but have not seen this. Does anyone else drive you vehicle? Is there an undisclosed FOD incident that you’re maybe unaware of?
Mine sticks. Didn't use to. I'm out of warranty now or I'd have it replaced.
Yes, get it fixed under your 3/36
Tfarrell73
Tim
New Lenox, Illinois
23 F150 Lightning Lariat ER
Mine sticks occasionally on a left lane change. Just partially pressing, not full click down
Ford Motor Company
Official Ford Account
Ford
F-150
bigtundra
Shane
apex
F150 Lightning
I'm having issues with mine sticking too. I reported it to my Ford dealer when they performed the latest recall SW update. They are supposed to order a new stalk and get back to me, but I haven't heard anything.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2002 Jeep Wrangler
Mech Engineer
You're not alone. Mine sticks too occasionally. Not enough to be a real problem, but definitely a bit annoying. Never thought about getting it replaced, might have to talk to the dealer next time I have it in.
Adventureboy
Mine stuck after they replaced it for the Heated Steering CSP. They replaced it under warranty and works well now.
scruvs
I'm good. Thank you, though. I scheduled my service through the FordPass app.
Lorincz
Joe
Mountain View, CA
2023 Ford F150 Lightning Platinum
Software Engineer
Mine sticks too. It's really annoying, especially considering how much this truck costs. Even my regular rental Toyota Corolla's turn signal lever is butter-smooth. I can’t wrap my head around why it’s so bad for a truck. Is it because it's a work vehicle? (Maybe they think you should be strong enough to drive it! :))
180ABL
Western MASS
2023 Avalanche Lightning Lariat ER
Mine was sticking also, dealer replaced under warrantee. Seems to be a common f150 issue.
Jim Lewis
San Antonio, TX
Mine sticks quite often on both left and right turns. To add insult to injury, in trying to coax it out of a stuck position, it often sticks in the opposite direction. Left stuck goes to right stuck and vice-versa. The Lightning has the worst turn signal behavior of any vehicle I've ever driven, including older model Ford and GMC vans, Honda, Toyota, Nissan, Chevy, and a slew of rental vehicles including trucks. It's a driving distraction and (pun intended) can send the wrong signal to other drivers. Maybe it's worth an NHTSA recall?
scruvs
I had mine replaced under warranty a couple days ago thanks to Taxman's nudge to quit messing around. It works like butter now. So, much so that I have muscle memory from turning off the blinker and it's like lifting an empty box -- not the force I expected.
Notes from paperwork:
Installed ML3Z 13K359 AA: Switch Asy.
I had to lean on the service advisor a little when they said that the tech couldn't duplicate the problem. I talked about how when it sticks, it's so unsafe because I can't get it turned off right away and then when I do the other blinker turns on, and that I think I need the part replaced or lubed or something, and they replaced the part.
scruvs
it’s been a month now and my new turn signal is still working great. I’m glad I got it replaced instead of living with it.
If you’re still under warranty, get it replaced.
If it happens to me again outside of my parts replacement warranty, I’ll look to replacing it myself at that time.
