vagabond7846
NJ
Inspired by TC Customs build ( http://instagr.am/p/CezlZslt1tv/ ), I did a similar setup. (Mine has no level kit and wheels are stock size)
This is black rhino rapid wheels, 20”, in gunmetal finish
Nitto grappler tires 275 (285s should fit too)
work was done by detail doctor in shrewsbury nj. They did an amazing job and also did a ceramic coat
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning B7F03417-C269-4685-9FEC-F9897F718109
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 1660761161242
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 1660761186056
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 299561894_728405354924625_1897710884958065046_n
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 299871851_3087804704863344_2903863422778156653_n
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 299728198_575157361022645_7787043911711874138_n
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 300052150_170616615532182_3072563346595175012_n
Ford F-150 Lightning Black Rhino Wheels & Nitto Grappler Tires installed on on Black Platinum Lightning 299372368_1129704821089009_7702209241528676814_n
F150ROD
U.S. Navy Retired
Maxx
It looks great. Do you mind sharing what is the hit on the range?
vagabond7846
NJ
Doesn’t seem to be any noticeable Difference yet but I haven’t done any long rides. The installer noted that this tire wheel combo weighs less than the stock, and I didn’t adjust height. So the only hit might be some aero but maybe less weight offsets that. There is more road noise as is to be expected.
I plan on doing a 200+ miles drive in a few weeks. I’ll report back
bryan995
François
San Diego
Love it - I am new to trucks. Can you ballpark the rim/tire/install price to me? :) <$2500?
No lift/leveling need correct?
vagabond7846
NJ
It was just under 5k installed and includes mounting, balancing, alignment, any speed adjustments, and moving the TPMS from factory to the new wheels.
there was no leveling done on this. I wanted the size to stay as close to stock as possible. I asked the installer to use 20” (stock platinum has 22 which was too big imo). The installer said 285 or 275s would fit. I went with 275s to keep it near stock
Roscoe95
Tim
MA
2022 Platinum delivered!
Looks great.. can you post the exact specs of the wheels?
vagabond7846
NJ
wheels are black rhino rapids, 20”, gunmetal finish
Tires are nitto ridge grappler 275/60R20
ResidualJinx
Erik
BMW X7, F-150 Lightning, Kia EV6
Any update on range loss with this mod? I'm thinking about going with a 285/50R20 Recon Grappler based on your comment from your installer that they would fit without leveling kit and other research I've done. The wheel is a +20 offset so hopefully that helps a little with the bigger tire.
vagabond7846
NJ
I am getting 2.2-2.7 mi/kW local driving (40mph average or lower). On the highway I am getting about 1.8 when going 75-85. About 2.0 if traveling at 60-65. These numbers seemed to match others with a stock setup according to another thread on this forum. So it’s hard to tell what the impact would be exactly but it appears to be mostly negligible and your rate of travel is a bigger factor.
as others have noted, doing a 2” level hits the range big time (same as ICE) but the tires alone here didn’t seem to make too much of a difference
Rob G
Rob
Monmouth County NJ
EQS580, Model X, Cybertruck, Hummer SUT
I’m in Rumson and plan in having the detail doctor do mine as well. Looks great
