hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
At times, the backup beep-beep is a tad annoying. But mostly it is a good thing.
I want to be able to disable it with the flip of a switch. The switch works perfectly, and now I can back up at home without waking up the kids. The UFO sound is also gone with the switch flipped.
First, remove the 3 plugs from the plate under the glove box.
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial 1
Then the PACModule is visible, fastened to the plate you just loosened.
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial 22
Remove the plug and cut this wire 5-10 cm from the plug. It's the speaker + terminal. Connect each end to each of a double wire, so you can complete the circuit with a switch.
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial 3
Run the double wire up through the A pillar and to the overhead console. The overhead console can be pulled down at the rear, it just hold in place with 4 clips. Unplug the three connectors. I placed my switch here. With the ON position towards the windshield. Connect the double wire to the switch.
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial 4
Final result:
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial 5
To avoid error messages, use for scan to disable AVAS:
Wrong Way Alert (WWA) • Approaching Audible System (AVAS) • Emergency Call System (ECS) • Brake Telltale Symbol (BTS)
720-09-02 x*xx xx--
0 = WWA disabled • AVAS disabled • ECS disabled • BTS U.S.
1 = WWA disabled • AVAS disabled • ECS disabled • BTS ROW
2 = WWA disabled • AVAS disabled • ECS enabled • BTS U.S.
3 = WWA disabled • AVAS disabled • ECS enabled • BTS ROW
4 = WWA disabled • AVAS enabled • ECS disabled • BTS U.S.
5 = WWA disabled • AVAS enabled • ECS disabled • BTS ROW
6 = WWA disabled • AVAS enabled • ECS enabled • BTS U.S.
7 = WWA disabled • AVAS enabled • ECS enabled • BTS ROW
8 = WWA enabled • AVAS disabled • ECS disabled • BTS U.S.
9 = WWA enabled • AVAS disabled • ECS disabled • BTS ROW
A = WWA enabled • AVAS disabled • ECS enabled • BTS U.S.
B = WWA enabled • AVAS disabled • ECS enabled • BTS ROW
C = WWA enabled • AVAS enabled • ECS disabled • BTS U.S.
D = WWA enabled • AVAS enabled • ECS disabled • BTS ROW
E = WWA enabled • AVAS enabled • ECS enabled • BTS U.S.
F = WWA enabled • AVAS enabled • ECS enabled • BTS ROW
Thanks to daczone for the excellent info in this thread, there you can find more information on the wire, plugs etc.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
This is an awesome mod for those who still want to keep the PAWS 99% of the time. I ripped that shit out day 1, but if I wasn't the only driver/owner I'd be highly interested in this and maybe use a relay who's coil is triggered by the interior lights?,, So, if the interior lights are ON, the speaker is off. Also, if you put the relay down at the PACM you can switch in a 100ohm resistor on the N.O. contact of the relay to replace the speaker and you don't even need to make any FORScan mods and retain the full PAWS malfunction warning.
Andrewbens
Modesto
Lightning
Mechanic
Great opportunity to add the advanced security with the overhead being pulled down.
hb.sagen
hb.sagen
Henning
Norway
What is this? I have read the option somewhere, but don't know what it adds.
d45
2024 F150 Lightning Flash
Hi here is another method for installing a physical switch to mute the external speaker. I wanted a purely physical system with no programming required, and no modification to the wiring harness. This method uses a switch in the cab to select if the signal goes to the speaker (on) or to a 4ohm resistor (off).
I ran two cables from the speaker through the firewall above the pedals. The cables plug in to the speakers using OEM connectors and basically re-routes the speaker signal into the cab where I select if its audible or not.
I used a mini SPDT switch mounted in the light control cluster. There is an empty slot that appears designed for switch (other trims may have something there). I mounted the 4ohm resister under the dash on the metal support above the pedals, which is great for heat dissipation and protecting the resistor from the elements.
It was some work running the wires and mounting the resistor but the results were worth it. 5000 miles driven now since modification with no issues.
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2813
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2815
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2816
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2818
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2844
Ford F-150 Lightning How to toggle the AVAS/PAC on/off with a physical switch - DIY tutorial IMG_2846
hb.sagen
hb.sagen
Henning
Norway
Great work d45!
astrand1
Alex
Studio truck driver
I did the same thing. I turned it off with forscan and unplugged at the dealer before I left. I think it’s ridiculous. There plenty of very quiet gas cars out there. At some point people need to be aware of their surroundings and look before walking in a parking lot.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
At work-sites I have to have a back up beeper, but at home I prefer to Not have one. This is a great solution for both situations.
ryun
Earth
How does a resistor replace forscan modifications? I'm guessing that it's because there's just enough resistance for the truck to still "see" the speakers still attached, but with enough impedance to prevent any sounds from playing?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
You are correct, pretty much any resistance even up to a thousand ohms will satisfy the warning that the speaker is not connected. When you hook it up, you are simply replacing the speaker with the resistor so no, No sound. Will play through a resistor.
RLXXI
3rd rock
Automotive Technician
Not complaining but I don't hear anything rolling forward to warn pedestrians of approaching silent vehicle, I do hear a muffled "boop""boop""boop" almost reminds me of a slow sonar echo at very low volume.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
When the external speaker is disabled, does the truck make any sound when going forward? I've always wondered if the truck is inherently silent. Do the motors make any sound?
