aeroengineer
This is a question I have too. Right now I have a Tesla wall connector hard wired on a 60A circuit inside my garage. I’m trying to plan what modifications will be needed, especially since the Lightning probably won’t fit in the garage. The easiest solution would be to install the charger included with the extended range battery model in place of the Tesla charger if it can be set to “only” charge to 48A. I assume this solution - if possible - might also eliminate the backup power function too.Anyone know if you will need a 100A circuit to use this 80A charger or can it be limited to lower current? IE: 40/50A?
