Shoebox72069
MN
2021 F150 Powerboost Lariat
Been working to update my APIM this evening.
FDRS is quite slow at burning a USB drive, it took far too long for a USB3 device. 32GB USB3 Patriot Memory (my most reliable and heavily used stick) doesn't quite seem to be getting detected.
It detects it in the sense where it will light up the top of the Sync screen saying "MyUSB Drive Detected", where as MyUSB being the name of the drive. Nothing after that, even with it sitting for 10 minutes. It was dark in the garage and I saw the read light on the drive light up, but only for those shining moments.
Tried a soft reset of the APIM via the Power + Seek keys. Reset it via FRDS, no dice. Waiting to get prompted for the download screen but no dice.
Leaving the USB in the truck to see if I makes a difference tomorrow when I take the kiddo to daycare.
Between waiting for the USB stick to burn and then being hopeful that my drive would be detected and it would start to pull down the updates.... Not a good way to spend 3 hours!
I've read through all the posts here and it seems like the APIM has a mind of its own. Perhaps I should ready an altar tomorrow?
I'm just hoping to make it through this APIM before 2 day license expires. Not to mention it is going to start to get pretty cold.
Edit: Didn't see a pending Gateway Module so I think I'm good to update the APIM.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Just my update. Tried the flash drive in the truck for a week. It did nada. I purchased the interface and such and will subscribe if needed but dealer still failed on their end.
Dealer replaced the APIM and still no go. Even after the GW update.
Wrote an email to my case rep and told her everything. If nobody can get this achieved, I requested a lemon buy back or replacement. So we shall see what happens today. Mechanic is super frustrated as am I.
Learned my lesson never to buy a first model of anything anymore. Ugh.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
That's crazy. I would have assumed installing a new APIM required some kind of programming routine that would in and of itself require a properly functioning APIM?
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I'm in the same boat as you. If you find some magical combo that works let us know. I'm goin on I think 2 weeks now with an untold amount of different USB drives all staying in the truck, no dice.
Shoebox72069
MN
At this point I'm not surprised I guess with everyone elses experience in this thread. I did take a couple short 5 minute jaunts around the neighborhood. Since I'm WFH'ing today I have the truck idling in the driveway (Powerboost). It's been running for just over a half hour and I'll check back here at the top of the hour again to see if it picked it up the drive. Bounced the APIM via the soft reset keys a few times this morning too.
I checked my USB drive and the contents is about 3.8GB which is roughly what other folks are reporting. Everything looks good as far as the drive goes. I use it for reformatting PC's, loading BIOS on other computers etc, so I'm quite confident the drive is in good shape.
I'll even dance in the driveway if needed! I don't think that will help unfortunately. It's nice outside currently but the wind is bringing in subzero temps again. I'll prefer to keep my truck running if I have to be sitting in messing with it at this point but it sounds like it is up to the USB gods really.
Wishing everyone else the best on getting their damn update to take!
BHunted1
Sumner County TN
You’d think it would go smooth. Jesse said he’s getting a serial number error. I read somewhere online that they were plug and play. But guess not. Extremely pist!
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Mine Finally updated!! Not sure if it was coincidence or not but I turned off my house Wi-Fi from sync the day before.
Just keep that USB stick in.
Ford F-150 Lightning ECU module programming guide using FDRS 86307F8B-82F8-47F8-BEAC-B0095A341E93
BHunted1
Sumner County TN
Tried that as well. Still didn’t work.
TJSparky
WA
Many thanks to Iceman and Jesse for help and tips. SpeedRacer my luck is with you since we have been battling this for awhile.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Hell yeah that's awesome! So just turned off wifi? You had the USB stick in all the time right?
Shoebox72069
MN
Oh man, running outside now to turn off the WiFi, I dont want to wait two weeks! :ROFLMAO:
TJSparky
WA
Hi SpeedRacer… yes I left the USB stick in and turned off WiFi completely (that connects to house) within Sync. About 24 hours later I noticed the auto updates and schedule updates allowed me to change the settings. After that the very old version of sync was listed in the About Sync area. (It was all blank for the longest time)
After seeing all that I pulled the USB stick, started up the truck, then re-inserted the stick… about 3-5 minutes later. BAM! The USB install notice popped up!
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Ford F-150 Lightning ECU module programming guide using FDRS 1643732697861
Well here goes nothing, fingers crossed that something that silly would kick it over.
Shoebox72069
MN
My truck has been on almost all morning (3 hours). Took it for another drive. Turned off Wifi as TJSparky mentioned, no change so far (not that I expected it that fast I guess).
My USB stick is very warm to the touch so you would think it is working perhaps but the read/write light isn't lit up though.
