Jesse-Infotainment
2024 F150 Lightning Platinum
If you want you can send your logs to Forscan and they will take a look.
When I do this I clear all my profiles. I also go to the folder they are stored in and erase all the previous logs.
C:\Users\USER NAME\AppData\Roaming\FORScan\log
Or you can go to the start go to forscan and select Forscan log folder and it will take you the folder.
Delete what is in there.
Then go and start a new session try to write the HVAC. when it gives the error disconnect and then take the files in that folder and email to
contact @forscan.com
Explain what is happening and if they can offer any help.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Ok thanks
ROBB1
Justin
NC
2021 F150 Tremor
not for me, no matter what I try, it will not write to HVAC. I get a service procedure interrupted failure every time.
2 cables
2 USB ports
Optimized settings
Write & write to all
Tried writing an unchanged As Built
Ignition off and on
HVAC off and on
HVAC module reset
I’m out of ideas on what could be causing this.
Last idea for you if you didn’t already try it: do not use the saved profile when you connect. Hit No and let I rescan the entire truck, then try to write the change.
MikeYQM
Moncton NB Canada
Thanks, I will try that
Ruffiano99
Joe
NY
2021 f150
Can someone explain to me what auto seat temp actually does? I dont get what the purpose of this is.
MikeYQM
Moncton NB Canada
it adjusts the heater and cooled seats to align the set HVAC temp. If HVAC is raising the temp, the heated seats come on varying the intensity to align. If the HVAC is lowering the temp, the cooled seats come on to align.
MikeYQM
Moncton NB Canada
So what have you done differently this time that it worked ? Did you use VCX Nano or ODBEx ?
i used the VCX Nano but I did a new profile when first connecting.
johnatuckeriii
Houston
2021 F-150 FX4 SuperCrew AMB
Hey guys... just wanted to chime in on the auto seat settings... ForScan will absolutely not take my settings for the Auto Seats; I was able to program in the prompt but "Service Interrupted" every time. OBDLink EX and VCX Nano and multiple new profiles as well as changing baud rates and latency.
I noticed @MikeYQM has a heated steering wheel... maybe my 500A just isn't fancy enough? :D
Ruffiano99
Joe
NY
2021 f150
I used the vcx nano to do the auto seats yesterday. Worked with no issues. I have a job 1 platinum with no sync updates. … guess that still makes me a loser… lol jp
ROBB1
Justin
NC
2021 F150 Tremor
Are you running the most current version of forscan?
Platinum Peasant
West Sacramento
I see options in forscan to enable the front and rear cameras for rock crawl mode, which I assumed were already working since I have rock crawl mode. Switched into the mode today and the cameras don’t work, they just default to the standard 360+ rear view. Any one else have rock crawl mode with no working cameras?
MikeYQM
Moncton NB Canada
did you click ‘no’ when you first connected the vehicle to ForScan and the box popped up for the profile?
johnatuckeriii
Houston
Hey guys... tried the "no" when opening Forscan too... version .46 (latest downloaded yesterday).
