ROBB1
Justin
NC
2021 F150 Tremor
every time I try to change the HVAC I get “Service Proceedure has been interupted” error and change won’t save.
any ideas anyone?
I'm in the same boat with my Job1 21 as well, I can't program HVAC at all. Have tried different versions of Forscan and am running a LinkEX as well now and still nothing.
The HVAC module is very slow to write. I was able to do it with a MX+. If you haven’t already, try to optimize your usb adapter latency and turn on auto increase in forscan.
https://forscan.org/forum/viewtopic.php?f=4&t=1763
GolfR
2022 F150 KR PB
I too am on Power Up 1.7.1, and I was also able to use Livinit Up’s sheet to manually change those 3 lines in the 2 modules, reset the APIM, and then the cameras in motion works for me now also! First button press gives hitch cam and second press gives 360 view with cargo cam.
I have a job 1 Platinum Powerboost with 7.2 Pro Power, and Blue Cruise Prep, purchased on 1/15/21. The last update I received notification of was 1.7.1, on 7/28/21, and nothing after that. I have installed the widget and I think it also says I have 1.7.1, so I have included some of the raw data for assistance.
Maybe someone can help me understand why it says Vehicle Not Drivable. And, how can I tell the failed update version?
Bed Cam & 360 Cam In Motion:
Hitch Cam:
Does the rear view camera still have the “full screen not available” black box? I would love to get rid of that!
sysop
Joe
2020 F150 Lariat 145 - 2022 F150 Lariat 157
worker bee
+1
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Disabling Pedestrian Alert Speaker - credit to Airborne_Ape for discovery
IPC 720-09-02 x*xx xx-- - if you have 4 then change to 0, if you have 5 then change to 1 AND disconnect PACM under the glovebox according to the video below. This has been added to the Common Spreadsheet.
I was so excited to see this, I am at work and ran out and followed the instructions and now I have the truck that I wanted. I do not feel like I own a contractor truck for a personal vehicle. Thank you for figuring this out.
ROBB1
Justin
NC
2021 F150 Tremor
I’ve been using a J2534? Pass through cable. I’ll try another cable.
If you have another cable available, I would recommend giving it a try. Some of the modules can be sensitive particularly the slower ones.
MikeYQM
Moncton NB Canada
I tried both my OBDLink EX and VCX Nano and no luck for either. Both optimized for peak performance.
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
I can confirm it will write to the HVAC, I have written to mine several times. I use the Vlinker FS
MikeYQM
Moncton NB Canada
not for me, no matter what I try, it will not write to HVAC. I get a service procedure interrupted failure every time.
2 cables
2 USB ports
Optimized settings
Write & write to all
Tried writing an unchanged As Built
Ignition off and on
HVAC off and on
HVAC module reset
I’m out of ideas on what could be causing this.
Jesse-Infotainment
Jesse
Dallas
Jesse-Infotainment
Jesse
Dallas
If you want you can send your logs to Forscan and they will take a look.
When I do this I clear all my profiles. I also go to the folder they are stored in and erase all the previous logs.
C:\Users\USER NAME\AppData\Roaming\FORScan\log
Or you can go to the start go to forscan and select Forscan log folder and it will take you the folder.
Delete what is in there.
Then go and start a new session try to write the HVAC. when it gives the error disconnect and then take the files in that folder and email to
contact @forscan.com
Explain what is happening and if they can offer any help.
MikeYQM
Moncton NB Canada
Ok thanks
ROBB1
Justin
NC
2021 F150 Tremor
2 cables
2 USB ports
Optimized settings
Ignition off and on
HVAC off and on
HVAC module reset
Last idea for you if you didn’t already try it: do not use the saved profile when you connect. Hit No and let I rescan the entire truck, then try to write the change.
MikeYQM
Moncton NB Canada
Thanks, I will try that
