I'm guessing they're sending out the updates now as in today since you didn't have it earlier...Mine is now showing the IPC update which I'm going to install right now.
It said 12 mins minimum when I started and I was at 20 when that honey walked by so... no clue.I like that the IPC is updateable via USB. I thought I read somewhere that others had to update via CAN and it was taking 6+ hours.
Mine showed the restart prompt after about 10minutes it was only 177Mb in files. I shut it off and started my 12 min timer. I have 8 minutes until I return and see if it was successful.It said 12 mins minimum when I started and I was at 20 when that honey walked by so... no clue.
The install until restart is 12mins so you should be done....Mine showed the restart prompt after about 10minutes it was only 177Mb in files. I shut it off and started my 12 min timer. I have 8 minutes until I return and see if it was successful.
Hmmmm...Well, 12min wait with the door open didn't work... Trying 32 minutes this time.
Get the restart loop?Well, 12min wait with the door open didn't work... Trying 32 minutes this time.
I need to stop looking in this thread...Mine is now showing the IPC update which I'm going to install right now.
How do you force it to go CAN?Ugh... I'm not playing this game with the restart crap. I'm updating it over CAN right now.
