iceman77
Pete
2022 Ford F-150 Platinum
Can anyone with a Job1 that is showing the SCCM update try to track down the VBF files and PM them to me?
I will flash them with Forscan or UCDS
The files are all stored in "C:\ProgramData\Ford Motor Company\FRDS\frds\data\vehicle_software"
you will need to determine which files are for the SCCM
Just grab any Job2 As-Built data, format it to XML, scroll down to very bottom, you will see NODE information there. The SCCM 724 is and Strategy info is F188 field. That should give you a pretty good indication what to look for.
Here's your info:
Ford F-150 Lightning ECU module programming guide using FDRS 1645631791430
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Here's your info:
@tonesto7 here you go then...
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Looks like my SCCM is already current
SCCM - Steering Column Control Module
Part number: ML3T-3F944-BG
Calibration level: ML3T-3F944-BG
Strategy : ML3T-14C579-AH
Bob_Mac
Bob
North Carolina
Ok, you do realize Ford pulled the BC until Q2 right? I'm thinking which we all knew that the IPC had to be done, but the SCCM which wasn't there when the BC was listed in the Programmable Features and now makes sense as well... maybe they need an update for ABS too?
tonesto7
Anthony
Where did you see Q2 for release?
Bob_Mac
Bob
North Carolina
Here's mine
Part number: ML3T-3F944-DG
Calibration level: ML3T-3F944-DG
Bob_Mac
Bob
North Carolina
That's one ford support specialist. It completely contradicts the dealer memo that was sent out.
No disagreement but my dealer told me not until Q2 at the earliest and that was stated yesterday.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
I would trust the communication sent to all dealers from Ford over the transcription of a customer service person leaving a voicemail for someone.
Bob_Mac
Bob
North Carolina
Agreed but as I stated, tech told me that they were told to hold off and no specific reason was given even when I asked.
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Has anyone looked today to see if the BC programming feature is available again in FDRS. I also noticed in my connected services that the BlueCruise coming soon is missing.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
That seems to come and go at random for most of us. I've had it come and go I think 3 times now.
Honestly, I see for Job 1 trucks a similar situation to the Raptor trucks. They will figure out the hardware or software just won't work with OTA or dealership updates and we'll all get a refund for the prep kit and they'll be done with us. Bluecruise itself is not the problem, Job 2 trucks are using it today. It's Job 1 trucks and it's either hardware or software limitations or both.
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
might be a dumb question, but how do you know if the truck is Job 1 or 2? Never needed to know, but curious.
