Twilly 3.0
Trevor
Alberta, Canada
2021 F150 3.0L Powerstroke, 2021 Edge SEL
It's lane keeping assist and you have it turned on; press the button on the steering wheel that matches this image telltale and it'll turn off
I pulled that picture from the interwebs and it looks slightly different, no lines on the side and the front sensing portion shows a vehicle and changes the colour from green to red when in traffic and I’m too close. It is definitely not lane keep assist. I just took these pictures.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? ECD98E12-467D-46C4-BA9B-54AFA6C85CEF
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? 5891FCA5-2265-488E-BFC8-655A6AC164EE
Livnitup
Livnitup
2021 F150 Platinum
The picture above is the Distance Indication feature is turned on under Features, Pre-Collision Assist Menu in Sync so turning that off will remove it.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? Distance Indication
CJ912
Corey
MI
2021 F150 Platinum 2017 Explorer Sport
Warehouse consultant
Has anybody had success with the 2021s and the Bluetooth version: OBDLink MX+ OBD2 Bluetooth Scanner?
I noticed that they recommend a USB version but I don’t want to use my only laptop (which is a work computer).
can’t wait to turn off the pedestrian back up sounds, every time I come home it wakes my wife up who works hospital hours!
Thanks
jabrego
Jason
Los Angeles
2021 F-150 4X4 Lariat 501A Sport
Thanks
Well you could always make your own adapter or buy one a member sells. I made my own sound delete jumper. for less than $10.
https://www.f150gen14.com/forum/threads/pedestrian-sounder-delete-no-codes-easily-reversible.6066/
https://megaohmmotorsports.bigcartel.com/products
CJ912
Corey
MI
That’s fantastic. Great tip on the homemade version.
I knew about the $60 version. Since I tow often and monitor suitcases and gas cans in the pick up bed I’m going for scan so I can also turn on the pick up bed camera.
abd79
Wayne
2021 F-150
Thanks
The MX adaptor is all I use. Have had no issues at all. The EX I believe is a usb wired version tested thoroughly with Forscan.
ROBB1
Justin
NC
2021 F150 Tremor
Thanks
I use the MX+ as well. It has been rock solid. Buy with confidence.
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
I am taking truck into dealership next week and wanted to restore module data back to original. When I first used FORScan, as recommended, I made backup copies of all modules. With my VIN when I downloaded the As Built file from Motorcraft and, using the compare tool I found a number of differences in the Motorcraft AS built file and individual backup module files. Is this normal? Using the compare tool, should I use the Motorcraft file or my backup files to return modules back to original for my dealer visit?
BCrippsy38
New Hampshire
2021 F-150 Lariat Powerboost
Interested as well. When I pull the BCM AB from the factory AB link on forscan I get a message saying the register / block count don't match up... not sure if this is due to my bad APIM and not having OTA updates or if there's something else going on.
Jesse-Infotainment
2024 F150 Lightning Platinum
The asbuild file online changes if you change it in certain modules. Also as updates are installed the as build can change. Ford will release a new as build and write it when the update is finished and once finished it will update the mothership. If you manually change as build the truck self reports every few days or so. The BCM, IPC, ACM seem to not self report and changes. Thats what I have seen with my truck at least. For other modules though even the gateway those changes will eventually report and change online
BCrippsy38
New Hampshire
So does that mean the "Factory AB" isn't really factory but a cloud backup of the current settings?
Jesse-Infotainment
Well I try to tell people when playing with Forscan to save your original file as it is before any changes because if you change something it will change there also. It’s not a static thing is the way I can put it. It’s not really a back up but it’s not static for the reason ford will change things in updates. Example the recent ipma update made as build changes and they were reflected online after the update. If they didnt reflect them and the next time some one did a config it would load wrong data that didn’t reflect the changes made for the update .
Older sync 3 cars did this also. For guys that did the 4-8 and had their cars on Wi-Fi it would report too sis they had sync 3.
So I suggest to anyone to save the online as build before you make any changes in Forscan. But even then if you update modules that original save could become outdated.
BCrippsy38
New Hampshire
Ok that makes sense. I saved all my modules when I first started making changes so I could revert back when bringing it in for major services. But sounds like that could cause problems as updates come out and the old original saved modules become outdated.
I was more concerned to see a meaage when I pull the BCM AB from the factory AB link on forscan it says the register / block count does't match up... I also have never recieved an OTA update, ever. My sync 4 version is 20312_product rev 243... just had the APIM swapped to fix the OTA issue but it still thinks it's up to date and on top of it I have the dimming screen issue now!...
RapidRedRick
Rick
Northern Virginia
IPMA module -made changes based on original backup file 4 days ago. Ran Motorcraft file this morning and compared it to the Motorcraft file I ran prior to making changes. The two Motorcraft files are identical.
1.How long does it take Mothership to update?
2. My truck has never received an OTA, could this be an indication it does not communicate with Mothership? I have set update screen to auto, as well as daily update with no differences. Tried WiFi and cell signal. I am sure I will get it eventually, but so far it has me stumped.
