Shoebox72069
MN
2021 F150 Powerboost Lariat
Huh, no Gateway module in that mess. A little surprised. Will have to avoid CCM/IPMA because of nano booby traps
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
I might have sometime this weekend to roll through what I can with the Nano safely (no IPMA).
Can someone see what presents I have waiting for me please? 1FTFW1ED8MFA91029
Thanks!
Don't try to update the Cruise Control Module with the Nano
Also the GWM module tends to pop up once certain modules are completed, so seeing it missing isn't that surprising.
antho
Anthony
Houston, Texas
2021 801A Raptor
If I'm not mistaken, the GWM update appears after the package CCM/IPMA/PSCM update completes?
Are these the modules that get an update to allow Bluecruise? trying to dig through this and see what exactly needs updated for BC. thanks.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Okay Im officially part of the Bluecruise club!
Check my doc here for an explanation of the tests. @iceman77 can you please update the link in the first post? Also, this is only for the Mongoose and there's no info for the Nano.
Okay we are all good my tests turned out f
Im good now
Ford F-150 Lightning ECU module programming guide using FDRS 20220317_175000
Ford F-150 Lightning ECU module programming guide using FDRS 20220317_175038
Ford F-150 Lightning ECU module programming guide using FDRS 20220317_175059
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Yea, it has to finish some procedure when it says "to complete the update restart the truck". So you shut the truck down, open the door, and many folks wait for several minutes before restarting the truck. Then you wait patiently for the Sync screen to inform you success and to remove the USB stick.
Then you tell FDRS Yes, and it runs the file verification against the module.
Ok been waiting about 10 minutes after restart . Man if it’s working in background it takes forever.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
It IS the final updates (appeared very recently) that prepares for BC.
Again, if I'm not mistaken.....these 3 showed up 3 or 4 days ago and then as soon as folks applied them the GWM update appeared and it was like a Bluecruise magic bullet.
Snakebitten
Coastal Texas
Exactly what step are you waiting at?
The Sync screen stating "restart the truck" and then you did?
If that is where you are and you did NOT get a repeat "restart your truck" command, then be happy that you are not in the dreaded "restart loop". ???
But yea, you just can't tell what's going on if you are waiting for "update successfull, you can remove the USB"
I'm not exactly sure what choices you have, but since you aren't in the restart loop, you certainly can shut the truck down and get out. Lock it. Get the Fob far away, and go eat some tacos and then try again? (start the truck and watch the top left corner of Sync for USB detected, then indexed. Then wait a few minutes again)
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Yes they are part of them. I just completed them, along with a GWM and *APIM and I have Blue Cruise working
JJ_Tex
Prosper, TX
2021 F150 Platinum Powerboost
Wow, I'm jealous of everyone getting their BlueCruise while I'm still hoping to get my 1.7.1 update. I do not "need" bluecruise for another 2 months for our cross-country road trip, and I'm not loving the idea of spending $500 on the mongoose + a Ford license. A couple of questions:
- The nano is much cheaper than the mongoose, but I understand it is not as good. Can it do the updates I need to get past my 1.7.1 failed update so I will at least start getting OTA updates again?
- Do we know if there will be an OTA fix for 1.7.1 or will the fix be a trip to the dealer?
- Anyone willing to sell their mongoose once they are done?
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Updating the vehicle in FDRS to any level does not currently fix the OTA issue. You get the updated modules, but as it stands will have to update them again in FDRS.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
It’s been a long wait.
Ford F-150 Lightning ECU module programming guide using FDRS 5F3B4247-C999-43C9-B319-759CC4D5EF8F
The new sync update fixed a lot of stuff as well.
RDS works again
Bed camera card works now.
Full screen rear cameras
The only item not fixed is the IPC remembering the last view bug.
nicholsbradley
Bradley
Louisiana
Analyst
So I am re-download and it’s installing now again and when it says restart I am going to get out and leave it until the morning . If no luck in morning guess I will have to go can route. First 4 fail and last few pass
