Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
Well, nuts. I knew the Nano would not update the CCM. I didn't realize the Nano would brick the CCM.
Anyone around Austin with a Mongoose willing to help out?
I live in Leander and can help, I have a forum member coming over Monday(depends on the weather) pm me if still needed.
jtake
2021 F150 King Ranch
I have the running boards not moving issue as well. I PMI'd the DSM with both original and new module, ran test, and configured, but not joy. Looking at the datalogging, the running boards are not shown for me as a test point.
Any suggestions?
Also, I too have the IPC DTC that will not reset. I am hoping I can PMI it in a day or so as well.
Got my power running boards fixed! I ran the PMI on the DSM as Not Original Module and all went well with no effect, boards still not moving. I then ran another test on the DSM module which this time moved the running boards. After this, all was fine. Thanks to everyone for all your help! 5 more hours on my 2 day (actually 3 day 6 hours) license, Still have the IPC DTC U2100 which has resisted several tests and a PMI both as new and original module. May give it one more shot tonight.
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Final note from me about my update experience (for now). I had Camera's at Speed and Glare Free lighting enabled, both of which had IPMA changes made. I didn't restore anything back to stock prior to updating my modules today. When I was done, no DTCs on any modules. I checked twice in FDRS before finishing and then also in FORScan as well. It seems that @Bob_Mac had a unique experience.
Shoebox72069
MN
2021 F150 Powerboost Lariat
Going on almost 8+ hours for this damn IPC. Finally on the tail end of 28k blocks! :ROFLMAO:
Shoebox72069
MN
So the update "mostly" finished. It had me turn on/off the car a couple of times at the end and then eventually it came up with
"Procedure Unsuccessful - ReadFalshActionDIDsFromModule
Update was not scucessful"
I hadn't done *any* scanning with the Nano. Eventually when I did at that point, I had every DTC possible for the APIM and IPC it looked like.
Trying to clear and retest now that I "scanned". I can tell the APIM seems a bit off as its missing a few digits at the end of it.
Voltage was rock solid at 13.6 the entire update....Truck seems fine but guess I need to sort through these DTCs now.
Platinum Peasant
West Sacramento
Any suggestions?
I have the same issue with the running boards, but this was post battery disconnect. Haven’t done yet the steps outlined by others to try and fix it. Ran out of time before work. I feel like Dumbo driving my truck to work with the running boards down ?
Shoebox72069
MN
Got the APIM DTC's all cleared up and tested positive. I did see the GWY pop up and at least that update seems to be running. Letting the vehicle sit a bit now for the restart.
Shoebox72069
MN
Feel like I let it sit for at least... 20 minutes. Started the truck back up and said it needed to restart again. Guess I need to let it sit a bit longer.
nicholsbradley
Bradley
Louisiana
Analyst
Dont feel bad mine had been doing that for 2 days. Never works with USB. Guess I will go CAN BUS route in a couple of days when i can get to my shop in Louisiana.
Shoebox72069
MN
Yeah I'm hoping I dont have to but probably will. Not super excited but not sure what I can do at this point.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Members helping Members out of a jam.
If Ford would do their own dam job we would not have to.
Sometimes when you Need to get something done you have to take matters into your own hands and get it done.
rpeterslll
Rob
Livonia, MI
2018 F150 Lariat FX4 Sport
IT Professional
How long has everyone waited after inserting the USB drive into the port in the truck before it started updating automatically? I’ve waited 10 minutes and never got a message. I can see that the USB drive is detected though when inserting.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
It usually detects the usb and then indexes the usb. Then theres a few minute wait and a message pops up saying system updating. You must hit close on sync screen for update to begin. Whats your voltage at on fdrs screen
