BCrippsy38
New Hampshire
2021 F-150 Lariat Powerboost
So do we need to worry about reverting to factory settings when going for a service at the dealer like with the last gen? Or is there a handful of modules that need to reverted that don't update like bcm?
Going in for another APIM swap this week or next.
Platinum Peasant
West Sacramento
Anyone recall exactly where in settings or in forscan that automatic heated/ cooled seats etc is controlled? I did a DSM module update and my heated/ cooled seats arent automatic anymore.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Here you go. I bookmarked it here in case I want to apply it at some point.
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
Sometime during a series of SW updates, not sure exactly which update, I lost Heated Steering and Heated/ Cooled seats functions. The rear heated seat buttons work, they are located on the center console facing the rear seats. The 5 On/Off buttons controlling the Heated Steering wheel and driver /passenger heated-cooled seats do not work. They are side by side and located on the dash underneath HVAC controls. The fact that I lost steering wheel and seat functions at the same time, and the buttons are side by side on the same row, make me think its a single problem.
Using FORScan I have changed AB 720-05-02-5xxx-xx__ to 720-05-02-0xxx-xx__ and then back to AB in an attempt to wake things up. This had no affect. There is a DSC in the IPC
Code: U2100 - Initial Configuration Not Complete
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
Could this DTC be the issue? I have not been able to clear this DTC using FORScan. Any suggestions would be greatly appreciated.
Veteran25A
Dennis
Kentucky
2022 F-150 Lariat
Soldier
When I try writing to the IPC module (specifically 720-09-02 to get rid of the pedestrian alarm) I get the following two errors:
Gain security access failed - security key is wrong
Service procedure has been interrupted
Any thoughts here as to what I'm doing wrong? I followed the guides exactly (to my knowledge)
My apologies if this has been asked previously in this thread, I tried searching for it but did not find it
RapidRedRick
Rick
Northern Virginia
@Veteran24A , have you seen this video?
Jesse-Infotainment
2024 F150 Lightning Platinum
Status:
If that is the error you have you may have the issue other have had where one half of the update installed only.
in fdrs when it first loads and lists the modules select ipc
at the bottom there will be a readout of all the info send me a pic of that info I’ll know if I can fix it for you like I have for a few others
Veteran25A
Dennis
Kentucky
2022 F-150 Lariat
Soldier
I have, this issue was with programming the IPC. I would get those log errors when attempting to write the change.
I tried again last night and it wrote successfully, the alarm is gone (thank god)...not sure what the cause of the error was or exactly what the fix was but hey, when in doubt "reboot" I guess
RapidRedRick
Rick
Northern Virginia
thx @Jesse-Infotainment , my FDRS license has run out. Been trying to fix this with nano and FORScan. It is time to bite the bullet and get the Mongoose /30 day license?
Spindrive
Matthew
F150
What is the latest power up out? I’ve been waiting to do camera in motion forscan change cause I saw it may be included in the next set of updates?
RapidRedRick
Rick
Northern Virginia
I re-uped my FDRS, here is a pic of the screen. Let me know if you need anything else. Really appreciate you looking at this.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? Screenshot (7)
ROBB1
Justin
NC
2021 F150 Tremor
Click no when forscan asks if you want to load a previous profile when you first connect. That usually takes care of that error.
John_C
2021 F150 XLT 302A PowerBoost
In regards to disabling the pedestrian alert speaker, has anybody done this successfully, going from a value "4", to a value "0"? I tried it on mine (has a 4 currently), but the speaker is still beeping in reverse as well as making the noise in drive. Any ideas?
imnuts
Dirty Jerz
Facilities Engineer
Did you unplug the module as well? It was stated in the post that detailed how to do it.
