FlasherZ
- Mar 10, 2022
- St. Louis Metro
- F-150 Lightning, Tesla Model X, F250 SD diesel 6.0
In newer homes, grounds and neutrals must be carried separately with only one high-current bonding connection at the service entrance containing the EGC. Otherwise it must be kept separate and no, they are absolutely NOT exactly the same. It's the number one confusion for those trying to understand the NEC - the difference between "grounded conductor" (neutral) and "groundING conductor (ground) and the myth that neutral and ground are the same thing.
With that said, as noted it's generally safe. There are fault conditions that carry more risk of shock by using neutral as a ground, usually having to do with that neutral becoming a path to ground for other current in the home. But good design has relegated thus risk to minimal.
Use the adapter for EV charging only, you'll be safe.
