- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
I'm plugged in and successfully charging, with 240v power, with a state park campground's TWO 30amp Outlets, via a 'combiner' adapter...
I acknowledge that this is a somewhat INFREQUENT solution to charging, as most campgrounds don't provide TWO 30amp RV outlets at each site, normally it's only ONE, and maybe a 20amp household GFCI outlet next to it. While many rv parks and other campgrounds might now give you full 240v power thru a 50amp 4-prong Outlet, many State Parks, especially older ones, do not, or have yet to 'remodel' the campground to provide a larger power source.
The success here is two fold:
First) you must have not only access to TWO 30amp outlets, which are each 120volts, but they also must be from the two different 'sides' of power, from the originating power source( the main electrical panel where their power lines originate from ). If Two outlets are provided, and each on their own breaker, then you have the possibility of receiving 240v power.
Second) you need to have the correct adapter, or 'combiner', to allow you to plug into BOTH 30amp outlets, and then plug your EVSE power cord's 4-prong 50amp into it's other end, which is a NEMA 14-50 female outlet. This adapter simply 'combines' the two incoming 30amp power into a single outlet that you can then use just like you do at home.
Notes:
There are several things that could prevent this option from working, such as weak or bad breakers, or the two breakers not originating from different 'sides' of the main panel(some call this out-of-phase or 'split phase')...
I also have an ADJUSTABLE EVSE for travel, since it can be dialed DOWN from 32 amps to 24, 20, 16 or 12amps, at 240volts, and I used that adjustment today, to change it down from 32, which could overtax the 30amp breakers, to 24amps, and it's working just fine. I'm also at the same time using ProPower onboard to power the CAMPER, from the truck, and WHILE it's Charging. Nice. : )
Notes:
