F150 Lightning FORscan thread
vandy1981
vandy1981
Tennessee
Plumber
FlasherZ
St. Louis Metro
Oops, I left the IPC settings off of the sticky. I just added them now. @FlasherZ and @jredondox, try the updated settings and let me know if it works.
I don't see any changes in the sticky - I think you added IPC settings to the wrong section (the auto-window stuff). I looked at the ICE thread and added the settings, and now I have the headlight with "A" in it. I'll see how it acts later.
I did notice that the HCM is now throwing DTC for "General Checksum Failure" which is lighting the MIL.
Code:
Code: U3000 - Control Module
Additional Fault Symptom:
- General Checksum Failure
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Headlamp Control Module
Clearing DTC's doesn't work - it just comes right back...
vandy1981
vandy1981
Tennessee
Plumber
Code:
Status:
Thanks, I moved it to the right section. Weird, did you get a checksum error when you wrote the changes to the HCM module? I double checked my HCM settings and this is what I have:
Ford F-150 Lightning F150 Lightning FORscan thread 1660514561370
vandy1981
vandy1981
Tennessee
Plumber
Code:
Status:
On second thought, did you use the ICE settings for 734-01-02? That setting threw a checksum error but the setting I used in the sticky from this thread worked fine.
FlasherZ
St. Louis Metro
No, used your settings except IPC. When I get home I'll restore the HCM and try again.
FlasherZ
St. Louis Metro
Ok - I restored HCM and followed the sticky instructions for HCM. I have differences compared to you (after mods):
Code:
             You-have          I-have
734-03-02    111E 1801 0189    111E 1801 0088
734-12-01    3146 5436 57A6    3146 5456 57C6
734-12-02    3145 5658 4EC1    3145 5638 4EA1
734-12-03    5747 3034 3587    5747 3038 378D
734-12-04    3438 BD           3535 BB
Lariat ER, tow tech, max tow.
If I use your full config, the checksum error isn't set, so it's obviously my "different" original numbers that trip it up.
The glare-free works regardless of whether your settings from above are used, or mine; just that MIL is set because of the cksum error if I use mine. It's a pretty nifty feature.
vandy1981
vandy1981
Tennessee
Plumber
Code:
             You-have          I-have
You may get more troubleshooting help if you visit the ICE thread. If you figure it out, please post the fix.
vandy1981
vandy1981
Tennessee
Plumber
What was your build date (or last 5 VIN rounded down to 1,000)?
I'd like to use that for posting there for comparison.
The production date was 5/5/22.
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
I got the checksum error and my mirror folding is wonky now. I have to reset and revisit the sticky. I’m sure, I know I shouldn’t be testing this after a long day at work.
jredondox
Jorge
San Diego, CA
2021 F150
I got the menu to show up. The right icons to show up on the cluster but I lost my adaptive headlights. They don’t move at all.
Ford F-150 Lightning F150 Lightning FORscan thread 09F2A38D-83B0-4BB7-9B58-1BC7025B6F91
Ford F-150 Lightning F150 Lightning FORscan thread 2ED2957B-5900-40C0-8D32-6F99D555F6F8
vandy1981
vandy1981
Tennessee
Plumber
I got the menu to show up. The right icon the cluster but I lost my adaptive headlights. They don’t move at all.
Do you have a Lariat SR, Lariat ER or Platinum?
jredondox
Jorge
San Diego, CA
2021 F150
You can change how many times your blinker clicks from 3 to 5 or 6.
724-01-01 XXXX-8CXX XX for 3 clicks
724-01-01 XXXX-94XX XX for 5 clicks
724-01-01 XXXX-98XX XX for 6 clicks
cvalue13
Austin, Texas
ā€˜22 Lightning ER Lariat
Fun-Employed
DRL forscan code from ice trucks work guys! I used the flashlight to simulate the sunlight and damn it’s bright!
this is pretty rad - could you grab a daytime pic for us when convenient?
I don’t know that I’ll take the leap into monkeying with FORscan, but I might beg the ICE forum for a central Texas ForScaner that would help for a case or something
