Best Home Charger that isn't the FCSP
GrokTime
Sean
Ithaca, NY
2022 F150 Lightning, Rivian R1S 1st Gen
Hello,
I received my extended range Lariat last week and love it. My Ford Charge Station Pro has not yet been delivered. However, I do not think I will ever need to charge at 80 amps and I have heard questionable things about the quality of the FCSP.
So, does anyone with more experience than I have any recommendations for a high quality home charger that will charge the Lightning at more than 32 amps? I am not looking for the cheapest option. I would like something quality with a reasonably long cord.
Thanks!
2000Firehawk
2022 Lightning Lariat ER
We have had a Clipper Creek (HCS-50 if I remember correctly) working flawlessly for us for years. Make sure to check out your electricity provider first though because they may provide rebates and/or discounts on certain makes/models - typically wifi connected models.
Dirtyrider89
Korey
Ohio
F150
Technician for cranes
I have a ChargePoint home flex works good for me.
duncanmaio
Duncan
Norwood, MA
I have a Chargepoint Home Flex at home and a ClipperCreek HCS-80 (64 amps output) at work. They both work great. The ClipperCreek doesn't have any smart features or connectivity - it just charges.
The Chargepoint has scheduling features that integrate with my utility to charge at off-peak rates and provide use and cost data. The interface isn't flawless but it's much better than the Ford app.
The ClipperCreek products seem much more robust than the Chargepoint, but I don't think the Chargepoint will be a problem even in outdoor applications.
sotek2345
Engineering Manager
It is only 40A, but I love our Grizzl-e. No advanced features, but a good price and very solidly built. Designed/built in Canada to withstand outdoor use in harsh winters. Longest possible J1772 cord (25')
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
JustB
Justin
Portland, ME
2023 F150 Lightning
How many amps are you guys getting? I am looking at Clippercreek. They have a 40 amp for $700 and a 48 amp for about $1k. Seems like the charging speed for 48 amps isn't much faster than 40 but it's hard to tell since ford doesn't really show different amperage comparisons outside of the Mobile Charger and the Pro Charger. I'm thinking the 40 amp should be just fine?
If you're going to spend $700, I would spend $50 more and get the ChargePoint Home Flex. It can charge up to 48A.
duncanmaio
Duncan
Norwood, MA
To get 48 amps, you have to hardwire. the NEMA 6-50 version of the Chargepoint is $599 on Amazon right now - and to hardwire you remove the plug cord, so it doesn't matter which plug type you get.
JustB
Justin
Portland, ME
2023 F150 Lightning
It looks like that one is only plug in. I have to mount outside and prefer the clean aesthetics of not having an extra box and plug outside.
I stopped looking at chargers when I bought my Emporia. If you can get the Chargepoint for $599 I would jump on that in a heartbeat. When I was looking at them they were $749.
You take the plug off and you can hardwire it.
duncanmaio
Duncan
Norwood, MA
And you can route the input wires through the back for a very clean install.
