Adding SecuriCode to Pro?
vbaker4444
Vic
2021 Mach E Select AWD
I noticed that my pro keys came with the SecuriCode access code for the "Keyless Entry System" even though I don't have that on the pro, nor is it an option. Has anyone else received the same and considering adding it? I found a tutorial on an older F150 on how to add it after the fact and I bet it's the exact same parts as the ICE 2022 version.
Here's the tutorial:
http://redassaggie00.blogspot.com/2018/05/how-to-adding-oem-keyless-entry-keypad.html
Matching Part# for 2022 Lightning Pro Exterior Door Moulding: Part #: 1520555
Unable to find an exact math for the keypad though. Here's the Part # that was included on the tutorial: Part #: 14A626
This might be a winter project for me to stay busy, but if anyone decides to do this, please add to this thread.
BennyTheBeaver
I too am interested in this
Mcalc55
F1504855
2022 Lightning Pro
Isnt there a more simple option where you just put the pad on with 3M Tape and then then dealer codes it?
broncoaz
Cape Cod, MA
Should be something like the one on my Bronco, sticks on with 3m tape. I would much prefer the F-150 one, but will buy the other one if necessary.
broncoaz
Cape Cod, MA
Here is a link for the trim piece, it shows 2015-2021. The part number fl3z1520555TA is supposed to be the matte finish.
https://www.tascaparts.com/oem-part...G6FslT5g8tAuFU6MLDABc1vlzo7tNpYIaAhCyEALw_wcB
I found a thread with the part number for the 2021 keypad, FL3Z14A626AF.
https://www.tascaparts.com/oem-parts/ford-keyless-lock-pad-fl3z14a626af?c=az0x
Here is the thread I was reading.
https://www.f150forum.com/f129/adding-key-pad-497804/index6/
I got my Lightning today and haven’t opened up the driver door to see if the plug is inside, but the code card was taped in the upper glove box.
RavenYZF-R6
Denver
Tacoma
Order it up and make me a video! ? Are you sure that’s not the piano black trim piece? I’d love to get this done in my Pro.
Lightninorian
Damon
CA
Rapid Red Pro
Firefighter
Great info. This is definitely something I would like to do to my Pro, just not brave enough to be the first. Another project is to add in the workstation console. My local parts department isn't very helpful on anything but the absolute basics. If their computer doesn't say it, they don't know.
Please keep us informed.
BennyTheBeaver
This looks awesome, something I want to do. Please confirm that trim piece matches the Pro for us!
broncoaz
Cape Cod, MA
Ok, I haven’t opened up the door panel to check for the plug, but I’m going to make the assumption that the plug is there. I just placed my order. Assuming everything is available I’ll know if this works in a couple weeks.
Ford F-150 Lightning Adding SecuriCode to Pro? 168FEF87-04B4-46AE-BF4E-C45A7727FC30
broncoaz
Cape Cod, MA
The keypad itself is on backorder. I ordered another from Tasca since their page showed it in stock. If anyone else knows where to find one please let me know.
Unfortunately, we've been informed by the manufacturer that the part you ordered is currently unavailable. We have canceled, and refunded your order.
Please allow 3-5 business days for the refund to post to your credit card.
PART #
FL3Z-14A626-AF1
broncoaz
Cape Cod, MA
I located a store in CA that had the FL3Z-14A626-AF keypad in stock, I bought two just in case. They might arrive this week.
The applique piece arrived today, FL3Z-1520555-TB is the matte piece but unfortunately they packaged it poorly from the factory (all the bubble wrap on the bottom and the cosmetic side against the cardboard protected by just a thin plastic bag) and it came scratched. I asked the vendor to send a replacement.
Ford F-150 Lightning Adding SecuriCode to Pro? F69D5CBA-6E2E-4DBE-ADD2-19D0C0A47B5A
BennyTheBeaver
Any new updates?
I, too, am wondering if the plug is in the door panel before I order...
broncoaz
Cape Cod, MA
Any new updates?
The keypads arrived Friday. I need to pull the door panel off and check for the plug. I sent back the damaged applique, they are ordering another one.
BennyTheBeaver
Keep us posted, please. I have a set I'm about to order and am curious if these are the correct parts and work?
RavenYZF-R6
Denver
Tacoma
Someone on FB posted that the wire was there but they haven’t activated in forescan yet. I received parts as well but I’m debating if I should replace the door speakers while I’m in there.
