Amp Powerstep Xtreme Installed
skyak
F250, 911, Lightning
These are model #AMP78152-01A.
Just curious. On my 2018 with AMP steps, when I opened the drivers side door only the drivers side step would deploy. On my 2021 with the factory steps, when I opened the drivers door both sides would deploy. Can you tell me how the 2021+ AMP steps work?
skyak
Driver's side doors open driver's steps only, passenger side doors opens passenger's steps only.
skyak
How did you deal with the ABS module on the driver side rear?
I just moved it up a few inches and secured it using only the higher bolt holes. Can take a picture later if you like.
Is there any indication that having the steps folded in like that improves efficiency at all? Or is the difference negligible?
Regardless, I love the feature and plan on getting it if/when I get my truck. Interestingly, when I took the Ford survey last month, it asked if I would add power steps to a lariat and I answered yes. Makes me wonder if 2024 MY will have the option.
PungoteagueDave
Where did you get them? Mine have been backordered for months.
skyak
skyak
Originally I had ordered my truck with power boards ($200 upcharge if I remember correctly), but unfortunately the option was cancelled by Ford. Factory would be nicer as you wouldn't need to do the after the fact wiring.
RavenYZF-R6
Denver
Tacoma
Yah sure, thanks. I ended up flipping mine upside down and using the left two bolts thinking straight up wouldn’t work, but I’d rather go your way.
skyak
Ford F-150 Lightning Amp Powerstep Xtreme Installed 1665780910157
Ford F-150 Lightning Amp Powerstep Xtreme Installed 1665780873530
918Nate
OK
Honda Fit
Not sure this is knowable without having a pro BUT, think these would work with a Pro trim?
skyak
I can’t see why they wouldn’t. I would assume the same running board studs are in place and the wiring would be the same.
BennyTheBeaver
Looking good!
I'm waiting on official support for the new Smart Series.
