Shortcut on main screen for camera possible?
Joneii
Central PA
F-150 Lightning, Tesla MY
agree, customizing the screen layout should be a standard thing.
Exactly, customizable is the way to go. I thought Ford had already done this when I saw the “My View” selection in the instrument cluster menu screen. “Perfect,” I thought, “I’ll just be able to select the various pieces of information that I find important and save it to my Driver Profile.” Well, needless to say I was disappointed to find out that My View just takes you to Calm Screen view. At least it is a way to hands-on select a view where I can see battery percentage without engaging my cruise control. So much wasted potential, Ford.
MickeyAO
Mickey
San Antonio Tx
Can I say how disappointed I am with this camera system? The GMC Sierra Denali I traded in for this truck had such a better system! The 360 view covered much more area around the truck (about double what I'm seeing on the Lightning) and if I moved from reverse to drive, or drive to reverse, the cameras would switch over. Guidelines were available on both the front and rear cameras.
That and the 24-hour clock (can't seem to get the vehicle to save it in military time) are really the only complaints I have with the Lightning...everything else beats all of the high-end trucks I've been driving for the last 15 years by a wide margin!
I have the same problem, this bug needs fixing!
Joneii
Central PA
My 24 hr clock works fine. I set it on 24 hrs when I picked it up a month ago, so I don’t remember what the steps were, but I do remember that it was simple. I wonder if it has something to do with the software version? My PAAK doesn’t work and I would gladly trade the 24 hr clock to get PAAK that works!
FirstF150InCasco
Boston MA
The best alternative is to briefly shift to reverse enabling the backup camera with the 360 view at the top of the screen. Be sure the rear camera delay is on, and the camera view will be persistent as long as you stay below 5 MPH or shift to P.
Good advice. Thanks.
FirstF150InCasco
Boston MA
24 hour clock has worked for me since I took delivery in June.
I can select the 24 hour mode, but the next day it's reverted to 12 hour, 6/6 BW, Built 6/30, in service 8/4
BennyTheBeaver
Maybe your CMOS battery needs to be replaced? (J/K)
Ford F-150 Lightning Shortcut on main screen for camera possible? Cr2032
BennyTheBeaver
Eric2XU
Eric
Boston, MA
F150 Lightning Lariat SR Anti-Mater Blue - Pending
For what its worth, Ford can totally fix all of these usability issues with Sync software. They could for example open up the top row for favorite settings areas and simply put stars in each screen you can press to add that area to the favorates bar sort of thing.
Now if they do it or not is the real question. I am for the moment going to give them the benifit of the doubt. I know they are busy with fixing more critial issues like how my truck always charges to 100% even though it clearly sees the truck at home and should charge to 80%.
If they really embrace the model of iterivitve software improvements over time the progression would be fixing ciritial issues first, but then turning to usablity ones. So say me, a computer enginner (that doesn't work for Ford).
There is also always the hope someone hacks the thing, fixes all the issues, then blocks future updates.
sotek2345
Engineering Manager
Do you have the truck set to "charge when plugged in" or did you define a charging window? "Charge when plugged in" overrides the charging limit. If you want to have the limit but also charge whenever, you need to define a 24hr charging window.
Yes it makes no sense and the usability is horrible, but it works.
Eric2XU
Eric
Boston, MA
yeah its not set to "charge when plugged in" although I have used that in the past before long trips. I get the feeling the app and the truck dont always sync correctly when that toggle is changed.
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
Agree on all the comments regarding the UI. Ford should get with Apple and take all their unused work on the apple car and create a new Ford interface. Or hire some top UI engineers that have worked for apple. Bottom line is that the most used functions when driving should be the easiest and least distracting to get to. Otherwise it is a serious safety issue and will cost lives at some point.
Since the car is a week or so old I am still learning but one surprising thing is that when I change lanes from left to right the camera does not automatically turn on to show view in the blind spot lane to right. This is a feature in just about every car with camera we have owned. Is it possible to turn this on in the lightning or did they leave this valuable safety feature out?[/QUOTE]
Joneii
Central PA
[/QUOTE]
I haven’t seen a way to do it other than leaving the camera screen up. It doesn’t have a setting to bring it up with the turn signal. The good news is that the mirrors are a good size and have yellow indicator lights if the vehicle detects an object in the blind spot.
