FordPass on Sync 4a Screen
I had issues making my mobile device and Ford Pass operate certain features of the truck remotely soon after my 8/4/2022 delivery, IIRC it functioning, then stopped after first power update, BTW, my truck is still at 3.5.4
I think many of you have experienced similar concerns.
While poking around the Sync 4a screen, I tried out the FordPass Icon under Apps.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670349442604
This triggered the following consents, I thought I had done this previously elsewhere in settings, but apparently what happens here has additional impact of truck telematic functions.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670352556467
Ford F-150 Lightning FordPass on Sync 4a Screen 1670352572729
Now "FordPass" is listed and you can tailor your consents at risk of losing functionality.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670352793228
Ford F-150 Lightning FordPass on Sync 4a Screen 1670352665519
Pro power onboard is now controllable from the mobile app truck still needs to be "Running"
You can switch the PPOB on and off (while truck is on), as well as the Front & Bed inverters.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670352921399
Scales work too, note you will see this pop up on the Sync console if the scales are displayed and you start the scales function in the App, either of them will warn and offer you to stay with or switch to the other mode of operation as you need it. Can not display both at the same time.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670353196262
Ford F-150 Lightning FordPass on Sync 4a Screen 1670353286663
Display of the scale data can be in either format, touch the ⇶ at the top right to show the scale display mode and the passenger load adjustments
Ford F-150 Lightning FordPass on Sync 4a Screen 1670353236370
Ford F-150 Lightning FordPass on Sync 4a Screen 1670353264553
jerock
Jerry
Kansas
Just looked at my screen & Fordpass is not listed.
jerock
Jerry
Kansas
I do have PAAK. All I can find on the newest update is Priority Update 22-PU0929-BLM-UP.
My last update was 11/2
I can't pinpoint why this suddenly started working, my last Ford Pass update was October 9th v4.22.0, Last Power up 3.5.4 on October 28th
jerock
Jerry
Kansas
I believe 3.5.4 was my last update also.
Viet658
Viet
Pomona, CA
2018 Tesla Model 3, 2022 Lightning Lariat ER
Yeah I didn't see Ford Pass in my Apps either. I could have sworn it was there recently too but got removed when Ford fixed my BlueCruise and Alexa issues. I recall there being the zone lighting in the app previously too but it's not there anymore. It's hard to keep track of the changes.
Android mobile device
---> FordPass
-------> Vehicle
------------> Features & Settings
All have always been present though would not work correctly.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670366802244
With the consents agreed to on the Trucks Sync 4A center stack screen, all are working now.
jerock
Jerry
Kansas
I wonder if the difference is you’re using Android Auto & I’m using Carplay
Possibly, hopefully more will comment on this thread from both camps......
White Lightning
Georgia
2022 IBSM F-150 Lightning Lariat ER
Pharmacist | Pharmacy Owner
I’m on CarPlay, PU 3.5.5, 22-PU0929-BLM-UP. PAAK is active, and we have the same Features & Settings in the FordPass app, but the Mobile Apps setting in the Sync4A settings is grayed out. Is it only active with Android Auto?
Ford F-150 Lightning FordPass on Sync 4a Screen 25B014DE-5361-4034-8C07-9C22F04F2BE5
Ford F-150 Lightning FordPass on Sync 4a Screen 77BAF3E6-BCFD-41C9-A495-BF75F5EC049B
Ford F-150 Lightning FordPass on Sync 4a Screen 874E004C-C8DE-46B3-89B2-D28F241FBCF2
Double check these steps.
Step 1
Click the Icon with the Lightning symbol for profile information
Ford F-150 Lightning FordPass on Sync 4a Screen 1670383693031
Step 2
Within that menu you should see a FordPass Icon under Apps, tap it
Ford F-150 Lightning FordPass on Sync 4a Screen 1670383816762
Step 3
Click Yes to allow these functions to work, the consent process to unlock the grayed out switch.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670383896225
Step 4
Return to Truck Menu, Settings, Mobile APPS,
Look for Mobile Apps switch to be on or tap to turn on.
If it's still grayed out, I have no idea why, other IOS users should confirm.
Ford F-150 Lightning FordPass on Sync 4a Screen 1670384006019
Blochead21
PA
Black 22 XLT 311pkg
I checked mine this morning on my 12”. The FordPass app didn’t show up until I opened the app on my phone. Once opened on my phone the app came up on the truck screen.
White Lightning
Georgia
Step 1
Step 2
Step 3
Step 4
I just don't have the FordPass icon on my screen, even with the FordPass app open and my iPhone connected to CarPlay. ?‍♂
Ford F-150 Lightning FordPass on Sync 4a Screen tempImagezEYo
iokua
2022 F150L Lariat ER / 2002 F350
Same here; no fordpass app on the screen. However, when I pulled out my iphone and woke it up to take a pic, the button appeared - when I pressed it, I was taken to the carplay screen and when I went back to the app page to try again, the fordpass button was gone. Sync has been really slow and laggy since my last update (3.5.4)....
