Android auto making outgoing calls not working
Yabra2
Sammamish, WA
F150 Lightning Lariat ER
Anybody else seeing the problem? Outgoing calls connect but no audio when using Android auto.
Works fine when not using Android auto on the car Bluetooth.
wighty
NY
I've never been able to get an outgoing call to work while android auto is connected. Galaxy S22 ultra
sotek2345
Engineering Manager
Yeah, I have lots of phone connecting issues with Android Auto. Usually takes 2 or 3 attempts.
I have found that this is only when you first get in the truck though, if you have been driving for awhile it seems to work, so something must still be booting in the background. Wife has the same issue on her Mach-e, but only the last few months. An update must have done something.
I've had issues in the past, but seldom take & make calls so it's not been a priority.
Pull up the phone device, and switch from AA to Bluetooth only connection, that resolved my concern the couple times I had it.
Yabra2
Sammamish, WA
Yes that works but it means no wireless AA. However I might just go with wired option since wireless failed to work few times.
Deleted member 12322
Guest
I'm also having this issue, I found that if I cycle to phone speaker and back it works, but sometimes the audio will cut out without warning. It's been pretty frustrating.
Aschool
Adam
Appleton, WI
2022 Ford F150 Lightning Lariat
Electrical Industry
I've had this issue on my 18 Larait and now the Lightning. No idea what causes it, but have had success with the speaker to truck cycle in getting it back as previously stated. Also, once the first call has been made, the rest typically work for that trip. Frustrating interface, but it's been like that for some time through S8 on through the S22.
MRButtler
Matt
2022 Lariat Lightning
Samsung's been updating android recently, so all apps are crapping out needing redownloads or user data wipes.
jazzmanmonty
Lincoln Corsair
self employeed
This has been ongoing problem for me too..I have a samsung zfold 3. Also usually happens for first phone call. My temp fix is while making a call, on the car screen, I toggle from bluetooth to speakerphone and back to bluetooth..that is the easiest way I've found and does the trick and dont have to touch my phone. I'm running the newest AA 8.9 coolwalk daily beta build and it still does it so idk if it's a samsung hardware thing or a Ford thing.
Yabra2
Sammamish, WA
It is most likely a Ford integration thing. I didn't have the issue with VW Atlas before the lightning on the same phone.
Also got coolwalk today and still happening.
Most likely this won't get fixed until Ford moves away from sync.
jazzmanmonty
Lincoln Corsair
self employeed
I'm hating sync as well. In my lincoln I have problems with the call echoing on the listeners. That happens with both wired connection and using AAWireless dongle. I don't remember if it was Ford or another manufacturer, but one of them were supposed to make android auto their primary OS. Let's hope all manufacturers follow suite.
Sidenote: my brother in law connected his iPhone to my lightning the other day. Talk about full screen! (PRO 12") AA needs to step up its full screen game stat. I hate apple, but that true full screen ui was nice!
wilmerfjohnson
Wilmer
Lehigh Valley PA
2023 XLT SR,2021 Bronco, 2018 Fusion, 2009 Mariner
Same here - Samsung Galaxy S22 S901U. The issue happens for me whether I am connected to the truck wireless or via USB-C. Outgoing calls only - the caller can hear me, but I cannot hear the caller. If the caller calls me back all is well. If I initiate the call on the phone instead of the Sync4 screen it works fine.
The same phone works fine (no issues) on my 2018 Fusion (wired only) and 2021 Bronco lux pkg, wireless and wired.
I still have intermittent issues with my Galaxy S10e, last event was an inbound call, I tapped to accept the call, I could not hear the caller but he could hear me. I hung and called out, that worked well. This is definitely intermittent though, other times I've received inbound calls with no issues.
I'm only reiterating this experience since we've had a few updates to both the truck side and phone side of the equation, but problems still linger.
OrangeCrush
Alpharetta, GA
2023 F-150 Lightning Lariat Antimatter Blue
Same issue with Galaxy Note 20. 2023 Lariat. Initiating the call on the phone seems to work. Not sure where to report this bug to Ford so tagging @Ford Motor Company
