Adding Co-Pilot Assist 2.0 with Forscan?
laselvasurf
Phil
Santa Cruz CA
This thread is amazing, thanks for all the info!
I have a 2023 XLT with the 360 cam and tow packages. I'm hoping to add lane centering and ACC. From what I can tell, I need the following:
Wiring Harness: ML3Z-15K867-NA
CCM: ML3Z-9E731-B
Switch: SW-7449
Beyond the parts, what is involved in the installation? Will I need to remove the front bumper or any other body parts to gain access to things? I'm fairly comfortable with forscan, so I think I could figure that out with the help of this thread.
Any info from those that have gotten everything working would be extremely helpful. Thanks!
Pod
2023 AMB Lightning XLT SR
So hope I can figure this out on my XLT 312A
biers
Thomas
SW Washington
2022 Pro SR upgraded to ER
This thread ended when the Lightning Forum was spun off. There is a VERY long thread about this on gen14. I spent the last hour going through the whole thing. This is the single best post to summarize what is needed and the very next one has a spreadsheet showing all the Forscan changes needed.
There is a lot of talk about if you have the "4 wires" to the bumper. I confirmed my 22 pro has these 4 wires.
#325
jdmackes
2023 F-150 Lightning Pro
#325
Are you planning on trying this on your pro? I'm interested to see if it's possible and what it'll take as I'm supposed to be getting a my23 pro in the next couple of months
wighty
NY
I'm investigating doing this for my 22 XLT 311a. The sensor assembly looks much cheaper than I was expecting based on reading some of the ICE forums regarding adding adaptive cruise.. $420 vs like $700 I saw for some of the linked parts.
laselvasurf
Phil
Santa Cruz CA
From what I've gathered, we need the following to make it work:
Sensor Assembly: ML3Z-9E731-G
Mounting Bolts(3x): W720714S450B
The total cost is just under $600 from most ford parts shops. l've very tempted to pull the trigger on this, but a bit nervous as I'm not sure anyone with a lightning as attempted to retrofit that sensor.
Ford F-150 Lightning Adding Co-Pilot Assist 2.0 with Forscan? Screenshot 2023-02-13 at 7.14.54 AM
Blochead21
PA
Black 22 XLT 311pkg
Someone always has to take the first leap of faith with mods. Worst case you can always sell the parts on the 14 gen forum if they don’t work out.
Pod
So steps are:
  • Buy parts
  • install parts ( should bolt right on )
  • Program via FORscan
Enjoy adaptive cruise
my wife’s Escape has co-pilot and I covet it greatly
laselvasurf
Phil
Santa Cruz CA
So steps are:
  • Buy parts
It seems like this is all we need to do. My biggest hesitation is installing the parts and removing the front bumper trim. I've done this plenty of times on my raptor, but there are far fewer wires/sensors. Also the raptor gets beat to hell off-road, so you'd never notice if I scratched anything...
3rdgenfan
Geoff
Delaware
Cybersecurity
Have you bought the parts yet?
...asking for a friend...
laselvasurf
Phil
Santa Cruz CA
Not yet... Been slammed with work and won't have time to do anything until a couple months from now. Also picked up a 2nd Excursion, so I've been a bit distracted getting that cleaned up.
This is still high on my list for the lightning though...
3rdgenfan
Geoff
Delaware
Cybersecurity
I know how that goes, in the same situation trying to get this Suburban 2500 cleaned up/de-fleet vehicle'd and ready to sell. Otherwise the ~$560 in parts was tempting to try; would be a bit more I guess if you gotta swap the switches around, may as well do the heated steering wheel setup.
